Ultra leaking oil out top of primary cover
Old 05-23-2008 | 12:28 PM
soon to be's Avatar
soon to be
Default Ultra leaking oil out top of primary cover
I have an 05 ultra with 3,000 miles on it. I bought it with 1900 miles....
The day i bought it, after the ride home, I noticed oil had leaked out (top side)primary cover betweeen cover and engine case, and down the side of the cover.
Note - I am not talking about the inspection cover or derby cover.
I checked and adjusted all the bolts for proper torque. It still leaked. I ordered and replaced the gasket, tighen the bolts in the proper order....i was happy. That is, until i rode the bike....still leaks, same place.
We are not talking alot of oil here. Is it though enough oil after a days ride to see it has run down the side of the cover. Before I take it apart again and check for flatness....any one else ever heard of this problem. If so what did you find?
thanks for the help!
Arite
Old 05-23-2008 | 12:43 PM
themensh's Avatar
themensh
Default RE: Ultra leaking oil out top of primary cover
Maybe use a small amount of gasket sealer?
Old 05-23-2008 | 01:41 PM
soon to be's Avatar
soon to be
OK....if I use gasket sealer....I am thinking i have to go around THE ENTIRE edge of the cover so it tightens up and seals evenly, right?
Or,are you suggesting only usingin the area it is leaking?
This is one of the reasons I posted....HDmanauldoes not say to use gasket sealers. Working on Metric bikes all my life, they almost always say use gasket sealers when appliying gaskets when putting parts together....gofigure!
Old 05-23-2008 | 01:49 PM
sleepneagle's Avatar
sleepneagle
you are positive it is leaking from the outer and inner primary mateing surfaces?
Old 05-23-2008 | 01:51 PM
soon to be's Avatar
soon to be
ORIGINAL: sleepneagle
YES!
Old 05-23-2008 | 01:55 PM
89FLHT's Avatar
89FLHT
If your used to wrenching on Metrics, then you know how good hondabond and yamabond are. On my primary I alwys use it and go around the entire gasket. Wroks great, fills in all the gaps and keeps it leak free...
Old 05-23-2008 | 02:32 PM
soon to be's Avatar
soon to be
ORIGINAL: 89FLHT
understand completely!
Old 05-25-2008 | 05:05 PM
Big Peter's Avatar
Big Peter
ORIGINAL: soon to be
Arite
Put Hylomar sealant on the gasket.
I always use it
Old 05-26-2008 | 04:42 AM
dpdorty's Avatar
dpdorty
Stage IV
I had the same issue, weeping oil from the upper portion of the cover. Since the bike wasunder warranty at the time, I took it to my local dealer for repair.They retorqued the bolts but the gasket still weeped oil.I decided to take care of it after that. I drained all of the fluid, thoroughly cleaned the cover and engine mating surfaces withpaper towels and solvent then applied a light coating of grease to both sides of the gasket. Reinstalled the cover and torqued the bolts to spec per the HD service manual. That was nearly 10 years ago and the weeping hasn't returned.
Old 05-26-2008 | 05:19 AM
jpooch00's Avatar
jpooch00
What Big Peter said!
Quick Reply: Ultra leaking oil out top of primary cover
