Ultra leaking oil out top of primary cover
RE: Ultra leaking oil out top of primary cover
ORIGINAL: Big Peter
Put Hylomar sealant on the gasket.
I always use it
ORIGINAL: soon to be
I have an 05 ultra with 3,000 miles on it. I bought it with 1900 miles....
The day i bought it, after the ride home, I noticed oil had leaked out (top side)primary cover betweeen cover and engine case, and down the side of the cover.
Note - I am not talking about the inspection cover or derby cover.
I checked and adjusted all the bolts for proper torque. It still leaked. I ordered and replaced the gasket, tighen the bolts in the proper order....i was happy. That is, until i rode the bike....still leaks, same place.
We are not talking alot of oil here. Is it though enough oil after a days ride to see it has run down the side of the cover. Before I take it apart again and check for flatness....any one else ever heard of this problem. If so what did you find?
thanks for the help!
Arite
Arite
I always use it
Scott Ballz
11-29-2013 04:04 PM
Monkeybutt2000
13
10-28-2012 11:51 AM
