4 qts of oil? no way
Just did a 5k service on my 07 RK and it shows full (when hot) with only about 3 3/4 qts. of oil put in it. Is this normal (as the dealer would say)? If about 8 oz of old oil stayed in, it sure does not look like the oil that I drained out. After running about ten miles the oil is clean and at the full mark when hot.
RE: 4 qts of oil? no way
ORIGINAL: 88b
If you put 4 quarts in ,it will blow at least 1/4 quart out of the air cleaner, I always set the oil level hot at 3/4 of the way up the dip stick
I put in 4 quarts. A couple times my bike took about 3 3/4, but I believe it was because I did not get the engine up to operating temperature like I should have, and thereby not completely draining the old oil. In other words, I did the change in too big a hurry. When I take my time and do it right, the crankcase takes all four quarts without overfilling. Iusually check my oil level cold on the jiffy stand. The level is halfway up the stick. Occasionally I will do a hot check just to see where it's at, and sure enough, the oil is at the full level where it should be.
ORIGINAL: txfxstrider
