Questions about handlebar install
Old 05-22-2008 | 08:20 PM
dawg's Avatar
dawg
Default RE: Questions about handlebar install
ORIGINAL: BLade1127
I take it that is the "cruise control", so to speak? Or is that just part of the internal throttle cable? We'll need to get the proper cable for internally wiring the bars.
That's the throttle sensor (hence no cables)
Old 05-22-2008 | 08:29 PM
BLade1127's Avatar
BLade1127
ORIGINAL: dawg
ORIGINAL: BLade1127
Got ya!! Makes my cables seem easier to work with!!
L2R - you'll have to pick this sensor cable up for internal wiring if you still want to run the wires in the handlebar. I wonder if H-Dog will have it in stock?? We may have to push it off a week if you can't get it.
Old 05-22-2008 | 08:36 PM
dawg's Avatar
dawg
ORIGINAL: BLade1127 I wonder if H-Dog will have it in stock?? We may have to push it off a week if you can't get it.
Only place in SC showing in stock..... ***'s Harley-Davidson of Rock Hill
Old 05-22-2008 | 08:38 PM
Live2Ride's Avatar
Live2Ride
Banned Camp
I'll go by the dealer tomorrow and check. I'm gonna go by my dad's place and mow his yard for him, since the doctor told him he can't because of the surgery. Then I'll swing by the dealer on the way home. I'll go ahead and probably pick up some wiring extensions also, just to be safe. Of course that's assuming the stuff isn't too expensive. I should be done by the time you get off work.
Old 05-22-2008 | 08:40 PM
dawg's Avatar
dawg
$89.95 throttle sensor. HD won't have extensions
Old 05-22-2008 | 08:43 PM
eagletalon's Avatar
eagletalon
i just installed 16" apes on my RK took me 20 hours of labor ! I know I Know! just a little more involved than i anticipated, you should get yourself a service manual also take notes while disasembleing, there is good info here if you search for it. the idol sensore switch is on your idol cable only needed if you plan on running cruise control and the switch plugs X two are under the naccele you will need to unplug each pin total of 6 per plug if you plan on running them internaly and possibly solder extintions this is just a fraction of what your up for. unless your throttle,idle,brake and clutchcables are long enough you have these to contend with your clutch cable if short will need replaceing this envolves removal of the transmisioncable cover not as accessable as you think at least not the bottom two of six bolts. good luck you can do it.
[IMG]local://upfiles/54875/845D52D7F6F94E369A810856B96284A3.jpg[/IMG]
Old 05-22-2008 | 08:58 PM
BLade1127's Avatar
BLade1127
Looks like I might be free to do something else tomorrow!!
Thanks for all the help guys!!
Old 05-22-2008 | 09:28 PM
Live2Ride's Avatar
Live2Ride
Banned Camp
Thanks for the help everyone. I'll talk to the dealer again tomorrow to make sure I have everything I need. I guess installin' the bars will be a learning experience.
Old 05-23-2008 | 03:21 AM
PapaTravis's Avatar
PapaTravis
Also, take a look at this site. It is not for the '08 model, but may help fill in the gaps of the link Dawg gave you. Have fun... http://mysite.wanadoo-members.co.uk/hhog/rkbarswap.pdf
rockstarbass1
11-05-2013 03:15 PM
idontknow
06-16-2011 10:51 AM
jackinthebox
03-18-2010 07:32 PM
Failz
06-01-2009 06:16 PM
fatboyfrankster
04-28-2007 06:53 AM
Quick Reply: Questions about handlebar install
