Starter Clutch Replacement
All,
I finally got my starter clutch in via UPS today. My question is this: can you install it w/out opening the primary up and taking the starter completely off? The service manual is about as vague as can be. According to it to do anything to the starter you have to remove it, but I know that's not true, so what about this? And, any pointers, cuz it seems very straightforward.
tia,
jason
tia,
jason
RE: Starter Clutch Replacement
06 and earlier tourers....you have to remove the primary cover to remove the starter drive so that you can then pull the starter out from the other side.
07 & 08....all you have to do is pull the starter...no removal of the primary is necessary.....the starters and clutch ring gear for the starters were re-vamped in 07...this actually started on the 06 dynas before introduction to all big twin models in 07.
