oil spray on the motor
I ride a 07 Road King. Coming back from Myrtle beach on sun I noticed oil film on the chrome, on the right side of the bike under the air cleaner. I took the cover off the air filter and noticed the filter had oil on it at the bottom. and its seems there was oil coming from the vent tube on the front cylinder. I have a stage one air cleaner and aftermarket pipes on my bike and just turned 10,000 miles..
Any ideas what is causing the oil leak???
RE: oil spray on the motor
do a search on this site. I am usre there are 5000 hits on this subject.
HD has a vneted crankcase that vents to the air cleaner.
Your pipes have nothgin to do with this....LOL...not sure why everyone thinks pipes are the issue on this issue...i digress.
Also, this is a design "feature" with HD.
I am sure others will chime in with a more technical explination. Basically, nothing to worry about, as long as your crankcase is not overfilled on oil. Oh yeah, this mayu or may not void your warranty....i had to add t
This is called"fuel stand off". The link below well provide a detailed description.
https://www.hdforums.com/fb.asp?m=3214585
ORIGINAL: Biggin65
It's the crankcase vent.
It has nothing to do with aftermarket pipes.
Peter
Good link there Bert. I've seen this one my bike more than once and each time it occurred was after I laid out a line with a nice rolling burnout, or after some high speed highway riding. My bike is plumbed with an external drip line between the vent holes and the breather to reroute the oil away from my breather. I also have an aftermarket T/B anda large air cleaner that gets saturated from time to time from the fuel standoff. For that reason, I take the breather off fairly often to clean and recharge it with the K&N recharge kit.
ORIGINAL: Biggin65
you're going to vent it into the filter and down the side of your bike.
Same with me, same machine. Just completed a 5000 mile service, oil was topped off, went on a 500+ mile out of town weekend, and when I returned home I noticed oil in the same place as yours. wiped it off, went out of town again for a 400+ mile weekend and - nothing, due to the oil level being a little bit below topped off.Follow cowboyglide's advice. Nothing to worry about. Everything is working fine.
