DIFFERENCE BETWEEN KHROME WERKS +2 SWEEPER AND WILD1 WO575
Old 05-20-2008, 07:47 AM
Duke of HD's Avatar
Duke of HD
Duke of HD is offline
Default DIFFERENCE BETWEEN KHROME WERKS +2 SWEEPER AND WILD1 WO575
So I am looking at two bars, Khrome Werks +2 sweepers 300515 and Wild 1 WO575 Chubby's for my FLHX.
What I want to know is what are the differences as faras hand placement and pullback and such? I know the Khrome Werks are only 1" but I understand they are set up for internal wiring now sowhats the diff???
I need some pull back dont care if I get any rise out of the bars!
I looked and it appears that the brake line on my scoot would be long enough (ABS), I understand I would need a clutch cable, what about the throttle by wire length?
Anyway, my main question........ What are the main differences between the WO575 and 300515 besides price and diameter?
Old 05-20-2008, 07:59 AM
dawg's Avatar
dawg
dawg is offline
Received 3,227 Likes on 1,842 Posts
Default RE: DIFFERENCE BETWEEN KHROME WERKS +2 SWEEPER AND WILD1 WO575
This shows various shots of them on a FLHX. If you search for my photos you will see the same shots of the sweepers on my scoot
http://www.wild1inc.com/575.html
Old 12-18-2009, 09:40 PM
patriotmc's Avatar
patriotmc
patriotmc is offline
Dawg, I'm down to these two bars as well. Going to put them on my 07 Ultra. I looked at the photo's of the Chubby's you have, couldn't find the Sweepers+2. If you have experience with both, would like to ask a couple of quesitons.
1. The Sweepers are +2 on height but I thought they were also +2 on the pull back. However in the following chart, it appears they pull back even less than stock.
Handlebar---------End Rise--------Width -------Ctr Width-----Pullback
Stock Ultra ---------7.5"----------31.0"-----------11.5"--------12.5"
Sweepers+2--------10.8"---------34.1"------------12.0"--------7.8"
Chubby 575---------10.0"---------34.5"-----------14.0"--------13.0"
2. Both the bars have about the same width. I've none had bars other than stock, does the extra width feel natural and can you still do counter steering ok? Do they both have similar wrist positions or is one better (your opinion)?
Winter time, so can't check them out on any bikes and dealer only has HD which I've ruled out.
Thanks
Thanks
Old 12-18-2009, 09:54 PM
Mr Cujo's Avatar
Mr Cujo
Mr Cujo is offline
following this one...
Old 12-18-2009, 11:33 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
KSGLIDEGUY is offline
I don't know the difference between the two bars but I can say for sure that the sweepers most definitely pull back a good 2" compared to stock. According to the chart in the above post the sweepers would lean you forward 4.5" more than stock. That is just not correct. I was also looking at these 2 bars and went with the sweepers because of the price and they really work great for me.
Old 12-19-2009, 05:54 AM
deezee's Avatar
deezee
deezee is offline
Im with KS glide......the sweepers will pull you back, Ive gottem on my flhx. They come back an inch or two further than the HD pullbacks. I love em.
Old 12-19-2009, 08:13 AM
dawg's Avatar
dawg
dawg is offline
The bars pull back farther than stock. The great thing is that they really change your wrist position. I found that cornering the bike is actually easier with the sweepers over stock. I really think that you would be happy with the sweepers. Here's some pics of them on my 04 and one compared to the stock bars
Old 12-19-2009, 08:38 AM
atrain68's Avatar
atrain68
atrain68 is offline
The Khromewerks +2 sweepers were the best addition I made this year. Far more comfortable than stock and I don't have to reach nearly as far. The grip angle is much straighter. The pullback number on that chart looks wrong. Where did that chart come from?
I agree with Dawg that the bars make cornering easier. This was a benefit I never expected.
As with any bars take some time to adjust the up/down tilt before tightening. It makes a big difference in comfort. I had to adjust once and it is amazing what a difference it makes.
Old 12-19-2009, 08:49 AM
77Tulsa's Avatar
77Tulsa
77Tulsa is offline
Wild ones are drilled for internal wiring and the sweapers are not.
Old 12-19-2009, 01:11 PM
frittsk's Avatar
frittsk
frittsk is offline
I put the Sweepers on last winter. Huge improvement for me, with the pull back and the wrist angle change. I drilled mine and stuffed the wires which was a bit more work but a fun project.
Quick Reply: DIFFERENCE BETWEEN KHROME WERKS +2 SWEEPER AND WILD1 WO575
