fuel line disconnect
I have a 2000 Road King Classic, fuel injected.Yesterday I noticed gas dripping from one of the fuel line disconnects. It eventually stopped on its own. When I turned the switch on there was a sudden quick stream of gas and then it went back to a good drip. The dealer said it was most likely an O ring somewhere in the upper portion of the disconnect that needed replacing. I need to get about 7-10 miles to my Indy repair shop. Do you think it would be safe to wrap it up with something to slow the flow and ride it? Any ideas would be appreciated.
RE: fuel line disconnect
HogBag07 I don't think he is talking about the cross over at the front of the tank he is talking about the fuel line with the quick disconnect at the left side of the tank.
Like the others I would not ride with a fuel leak, you are just asking for problems. This is something that you can do yourself just pop the line off, it is a quick disconnect. Pull the o-ring out with a pick tool and replace it. Should take you less the 5 mins and 2 bucks in parts.
Jeff
Jeff
You may get lucky and it be the male portion that leads to the manifold but not likely. It's typically the female part of the quick disconnect that is connected to the tank. The only pain about the fix is removing the pump/float assembly from the tank. It's like packing 10lb of "stuff" in a 5lb hole.
You can do it though, just take your time and be careful not to bend the float.
If it's an EZ-Flow Quick Disconnect (and i bet it is), Jeff is right. It's the o-ring seal on the male end. EX-Flow is out of business now so you may have to get creative to figure out what size you need, but generally speaking it's a pretty easy fix.
Worst case, just replace it with a slingle piece of 5/16 neopreme fuel line.
I would not ride it either.... something about spilling fuel on that front exhaust pipe, right at the head, that I'm not totally cool with.
From what I'm reading here.................it has nothing to do with the crossover line at the front of the tank. He's talking about the connection on the left side of the tank that goes to the throttle body. Take it apart and make sure it looks OK........sometimes they just need to be reset and they seal up fine.
Last week I finished up 2 builds, and both bikes leaked at first from the quick-disconnects when first fired up. I took the connection apart, put it back together and they were both fine. Maybe put a little Vaseline on the male connection so it will slide into the female connection a little easier and seat with the o-ring in there.
Steve
Steve
