Oil Cooler suggestions!!
RE: Oil Cooler suggestions!!
Original: buzzard07
I'm wanting to putan oil cooler on my 07 EGC , does anyone have any opinions or suggestions for a decent one that will actually do a good job for me.I'm just wanting to make sure I can get the bike as cool as possible to avoid any troubles down the road.Thanks in advance for any help.
ORIGINAL: bob_kikkert
Since the Ultra is a new machine for me, I am curious about this oil cooler thing. Have some of you had engine problems in hot weather without an oil cooler? Is there a temperature where the bike starts to cause problems? My 08 will shut down one cyclinder when idling in very hot weather......is this new to the 08 and if not does it help?
We plan on riding Route 66 either next year or the year after and could encounter some hot weather. Would I be better off with an oil cooler?
I have the HD Premium with thermostat, which has been excellent. A good alternative would be the Jagg 10-row, but be sure to buy the thermostat, as it is not standard with the cooler. The HD cooler has the t'stat in the kit. If you buy the HD model, heed the warnings you've already heard about the 7/16" Allen wrench, as it is required to install the t'stat filter adapter. A socket would be preferable since there is a torque value for this fitting. You can use a bolt with a 7/16" head and jam two nuts of any head size on the other end. Place the 7/16" head in the fitting and torque down with a ratchet from the nut side. Other than this, the cooler install procedure is very simple and quick. On an '07, don't pay any attention to the instructions where they say to re-route the VR wires, as this is not necessary and it fits without alteration.
I've been looking at this one from Jagg , but it looks like a $300+ investment after you buy the adapter that it says it needs but doesn't come with.
http://www.jpcycles.com/productgroup...amp;brand=jagg
I guess I'll check out the HD one too.
Is this one any better than the Jagg?
It looks like it'll cost $300 either way.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
