the Stealth Rack is an easy install. Just be ready to loosen up all the bolts and screws common to the areas supporting the rack itself. It took me 45 minutes to get it all worked out. As long as you have all the right tools...patience...you'll do fine!
I think I had to pry it into position with a screwdriver, then the bolt holes didn't line up. Just your typical harleyaccessory installation.Not reallyall that bad and it looks good too.
