Smart Siren II
Hey everyone, another post. I just ordered a HD Smart Siren II and Smart Siren II remote reciever. Has anyone installed one of these units. It's going in my 98 RK. Do I also need to purchase the Security System Key Fob seperately? No one at my local dealer seems to know if the key fob comes with the smart siren in the package. Can anyone give me any info. and advice? Thanks, Kenny
ORIGINAL: W2KOP
If the TSSM is not installed then the siren and pager won't do you a whole lot of good. [:@]
There was one fob in the box with my TSSM.
I was not told that I needed a turn signal security module by the guys in the parts dept. at my local HD dealer. The unit I ordered is supposed to be self contained, siren, transmitter and battery backup in one unit. It is HD part #68317-06 which fits 97-01 Touring models. I also purchased the HD Security System Pager Reciever II which goes with the Smart Siren II. The HD part number for the Pager Reciever is 91660-06. I was really curious if the unit came with the key fob, which I have been told that it does not.
I put the Smart Siren II on my street Glide and purchased the pager. Both work OK. But your bike must have the factory "security system" from the factory. Or you have to order this also from the catalog and install at same time. The Smart Siren plugs into the factory security system.
The fobs come with the security system. I bought an extra off Ebay when I broke one. Easy to configure for the security system.
SOOS, Thanks, well you know more than the parts guys here at my local HD dealer. No problem, I will have to spend the extra money on the alarm, and the installation kit. Do you know how hard it is to "install the installation kit" I can turn a wrench and do quite a bit of my own work, or is this something that should be left to the HD dealer? Thanks, Ken
I Just went out and pulled the seat off my ride and the security module looks to be just a plug-in unit right behind the battery on the right side. On mine, there is a knockout opening for the module to sit in and then it is held in place with a clip.
[IMG]local://upfiles/4575/6B42B0A85DCA41D9AEAEEE076B930D88.gif[/IMG]
Remove the right panel of your bike. They just pop right off and are held in place by 3 tabs securing 3 corners of the panel. There are rubber fittings attached to the tabs so that they fit securly to the bike. Once removed you will notice the ECM for your bike. The siren will be located behind that ECM. This of course directly plugs in to the Alarm which you do not yet have installed. I haven't checked my service manual for Alarm Installation to see where it is mounted, but I would say the location next to the battery makes sense because that places it in the vicinity of where the siren is to be installed (behind the right panel) as noted above.
