08 Street Glide Rinehart TD's and Big City Thunder baffles!/video
RE: Rinehart's and Big City Thunder!!!!!!!!!
ORIGINAL: MassHD
Did you have change the SERT setting or is it a direct replacement?
ORIGINAL: drrandall1
Part # for baffles #2004
There is no part number for adapter it's called Rinehart adapter. They will know.
ORIGINAL: cowboyglide
drrandall I also have the RH TDs on my 07 SG with the performance baffles and I have never cared for the gurgling soundallof their bafflesmake on decell. I would like to order the same thingyoudid. Whatare the big city baffle and adaptor part numbers you bought.
Thanks in advance
Thanks in advance
I just ordered the 2004 baffle and adaptor. They should be here Wed. I'm putting my faith in your evaluation Drrandall1.
07 SG, TMax w/AT, 90 Wimmer Black Filter, RH TDs
I inserted the baffles inthe headpipe flush where the mufflers slip on. I took the baffles out of the Rinehart mufflers completely. Gail at BCT said you could do it either way. If you leave the baffles in you will get the same sound just deeper. Take the baffles out and you get LOUDER and deeper.
