If "true duals" are so great......
RE: If "true duals" are so great......
It's not so much a matter of the exhuast pipe length as it is the exhaust pipe's internal volume. The internal volume need to be within certain measurements specific to the engine it's attached to.Volumeof course can beincreased by length but also from diameter. Notice the 2 -1 pipesgenerally have a larger diameter. Problem is at some point an exhaust pipe beings to look stupid if it's too fat. Look at that god forsaken thing on the Yamaha Road Warrior.[:'(]
ORIGINAL: steveh326
it's my understanding also that the other part of scavenging on a 2-1 orcrossover pipe is the exhaust pulse from one cylinder creates a vacuum effect in the pipe to help pull/scavenge the exhaust gas from the other cylinder. your comment about longer pipes being less efficient makes sense, as the exhaust flow would lose velocity over distance, making itless effective.
I love the performance aspect of 2-1 pipes, but I will eventually be going with true duals cause I like the cleaner look.
ORIGINAL: Hoffy
Its not back pressure. Its called exhaust scavenging effect. The longer the exhaust pipe, the less scavenging occurs, thus on touring bikes a cross over is designed into the system to improve scavenging. Scavenging is when when the exhaust gasses are not only pushed out out by the up stroke but also sucked out from the exhaust pipe end, which allows more fresh atomized fuel to enter the combustion chamber, which leads to more downward pressure on the piston during ignition. Without a cross over there is a lower volume of atomized fuel that can enter the combustion chamber, which is why true duals loose some low end torque.
ORIGINAL: Hoffy
I have true duals because I like the look and sound. Can't get into it with performance because never tried the stock pipes. I really don't know many friends that left the stock exhaust on. HD dealers really makes some extra bucks by selling or installing new ones. Most people on the forum have changed pipes $$$. It's like why do you pay $20K plus and not have a windshield trim??? $$$[/align]
