engine light comes on after it goes off
i have a 07 sg and just did a stage one, fatcats, big sucker, and pwr111, i down loaded the rite map, even had tech support confirm it, engine lite comes when ignition is turned on, i wait for it to go off and start my bike, then it comes back on for a few secs and goes off again and stays off, the bike runs great. anyone with some input would be helpful, thanx
RE: engine light comes on after it goes off
Jeff, it should throw you a code go to this thread and follow the directions and you will know what is going on...Jer
https://www.hdforums.com/m_43975/tm.htm
i would clear the codes and run the bike see if they come back....if they do, then clear the codes and take the PCIII back off and run it...if they do not come back then the PCIII is messed up send it back for a new one....if it come back with the PCIII diconnected then you have a issue that needs to be looked at by a dealer
