Handle bar wobble at 30 to 40 mph
RE: Handle bar wobble at 30 to 40 mph
This is not normal first check tire pressure/direction. Next ensure you have not changed your load or its distribution on the bike then if all is good there insist that they check the neck and wheel bearings which are the next most likely causes. also upgrade your life insurance if they tell you it is normal and have them put it on paper.
Nuts! No problem on mine or anyone else to my knowledge...As others have said...alignment, tire pressure, bushings, rear shock pressure etc....Why do you see so many HD tour bikes on the nations highways....It's cause they are the flagship of cruising, and have been for a long time!
milo8155
07 FLHX
03 FXST
Collierville,TN
milo8155
07 FLHX
03 FXST
Collierville,TN
mestude
10-26-2011 08:28 AM
