Cracked header pipes
Old 05-15-2008, 11:54 AM
SaltyBagger's Avatar
SaltyBagger
SaltyBagger is offline
Default RE: Cracked header pipes
That's a very common failure point and why I went to a Fulsac true dual exhaust. I had the pipe welded once and it only lasted a month or so. The Fulsac was was cheaper than a new pipe from the dealer.
Old 05-15-2008, 12:13 PM
IRideMineEverywhere's Avatar
IRideMineEverywhere
IRideMineEverywhere is offline
Mine had a 3" crack at the "Y" exiting the rear cylinder. Didn't get any louder but I could definitely smell a leak somewhere... Didn't want to screw with getting it welded and just went to V&H true duals.... I've talkedto my local dealer and Indy about the problem and they both said it was widespread. Dealer also said it was covered under warranty for replacement.....
Old 05-15-2008, 03:03 PM
Neil's Avatar
Neil
Neil is offline
Unfortuneately my bike is way out of warranty. Eventualy I will add a set of true duals, most likely VH to go with my slip ons. At this point I have two freinds that replaced their exhaust with Rineharts so I have two sets of pipes to go through before I need to replace the whole thing. The only thing is I hope I can get the nuts off the studs without any problems...
Neil
RDMC
roaddawgs.com
Old 05-15-2008, 03:58 PM
dowork08's Avatar
dowork08
dowork08 is offline
i havent see the stock pipe crack but man i had my bub 7's pn my 08 look like it was going to melt it was so hot and red
Old 05-15-2008, 05:15 PM
dgriffith's Avatar
dgriffith
dgriffith is offline
While you are down there looking at that crack on the pipe look at the mounting point just down the pipe. If that mount gets loose it will put stress on that joint, causing it to crack. Mine had less than 5,000 miles and 3 months old when it broke. The person on the assembly line must have omitted torquing the nut on mine, it was gone. Almost 2 years later, 24,000 miles, no crack, no noise. Something to check.
Old 05-16-2008, 06:48 AM
harpoon's Avatar
harpoon
harpoon is offline
This stuff is the best and will get any nut off.. Except your own, it stings quite a bit. don't ask me how I know. LOL
PB Blaster
Old 05-16-2008, 06:51 AM
harpoon's Avatar
harpoon
harpoon is offline
Sorry for some reason the pic didn't post for you to see.
[IMG]local://upfiles/4888/A096189C6D8A48FCBA99326303E65DA0.jpg[/IMG]
Old 05-16-2008, 08:28 AM
old95's Avatar
old95
old95 is offline
Had the same @ about 43,000, covered under warrenty.
Old 05-16-2008, 08:13 PM
firstimer's Avatar
firstimer
firstimer is offline
had a dealer tell me that they break alot from too much engine braking. and to check front lower motor mount, that would probly be bad also, and it was. thats what i get fer buying a bike with 45000 miles.
Old 05-16-2008, 09:29 PM
R8BOOMER's Avatar
R8BOOMER
R8BOOMER is offline
6th Gear
Mine cracked twice also. Once during a trip and became very loud all of a sudden. The other time there was no increase in sound but was discovered during a 95" kit install so I switched to v/h true duals and have had no more problems!
Wooddy04EGUC
Exhaust System Topics
02-22-2017 05:39 AM
T_Sebastian
12-18-2011 12:32 PM
Beechnut
07-13-2011 01:59 PM
ironhide_uk
05-27-2011 04:54 PM
Red Bull
08-06-2010 06:05 AM
Quick Reply: Cracked header pipes
