exhaust flange question
Old 05-13-2008 | 09:42 PM
SPARKY01's Avatar
SPARKY01
Default exhaust flange question
need some imput to put my feeble mind to ease. installed my new ridestr8 tonite (lets not even go there) and of course you have to loosen the exhaust mounts and the flanges at the heads so you can pull it away a little bit to r/r the frame bracket. as ya'll know you can get to one nut on each cylinder woth a straight socket but the second nut on each cylinder is at a weird angle and you cannot get a socket on it, much less torque with a torque wrench. i tightened evenly and the torque one nut down and tried to match the second one by feel. don't noticed anything popping, etc. but a little nervous about leakage and if so, is it a problem. any ideas/suggestions? don't want to f^%k up 20k worth of bike...wife would kick my ***!!! thanks for any suggestions!!!!
Old 05-13-2008 | 10:42 PM
RKKY's Avatar
RKKY
Default RE: exhaust flange question
I use a 1/4" universal with 1/2" deep socket on most if there's room and a 1/2" swivel socket there isn't. Fairly inexpensive way to put your mind at ease if you are worrying about it. If there as a problem with yours (intake leak) you should notice it. Should also check every so often to make sure it isn't working it's way down (off) the stud.
Old 05-13-2008 | 10:44 PM
SPARKY01's Avatar
SPARKY01
thanks. just a little nervous that i did it right. used a swivel but kinda strange feel to it.
RayBoy
08-20-2020 07:42 PM
mikeo33y
09-10-2016 11:02 PM
mking7
04-07-2011 10:01 AM
rhoppe
08-29-2008 10:51 AM
SPARKY01
Exhaust System Topics
05-13-2008 11:54 PM
Quick Reply: exhaust flange question
