SPARK PLUGS
RE: SPARK PLUGS
Last summer I switched to Autolite 4163, one heat range colder than stock, and have been running them ever since. Stock is 4164. No problems at all and the ion-discharge knock sensor appears to be working properly with these plugs. These were much cheaper than the HD-branded plugs, and be purchased at Auto Zone and other auto-parts franchises. Other good brands include Denso, NGK, etc.
RE: SPARK PLUGS
ORIGINAL: langlois1
I KNOW SOMEONE WILL BE ABLE TO ANSWER THIS QUESTION. WHICH IS WHEN CHANGEING SPARK PLUGS DO YOU HAVE TO USE HARLEY BRAND?
RE: SPARK PLUGS
ORIGINAL: langlois1
"A small voltage is applied across the plug electrodes during while the power and exhaust phases of the cylinder are in progress." Ref: Adam Wade Motorcycle Fuel injection pp. 61
I'm not sure if substitute plugs will have the same resistance values as the HD plugs.
Gary
RE: SPARK PLUGS
No you can use any brand you want just make sure it is the correct heat range.
That said the standaed HD plugs are fine.
those fancy 2 or 3 times the cost Platium plated extra specila BS plugs do nothing more than last a bit longer and if you change your plugs as you should there is no reason to use them.
Other than it may make you feel good.
NO spark plugs with 4 contacts do not burn fuel better and indexing is a joke
caperss396
12-01-2006 10:04 PM
