Aux lights on FLHX
#32
RE: Aux lights on FLHX
You also need special HD tool to crimp the pins correctly.
If you don't they may not stay locked in the plastic harness module.
Took the assembly to my dealer service mgr, he crimped them for meso I didn't have to buy the tool.
Still wanted to tie into the low beam power so the passing lamps would stay on when flippin' to high beam. (but didn't)
I run an "a**hole bright" H4 bulb in the main lamp. 100w high 80 low.
#33
http://a1276.g.akamai.net/7/1276/734...M_1f72e.Custom Auxiliary Lighting Bracket Kit
Shaped by the wind, these Custom Auxiliary Lighting Brackets blend into the curving contours of the Street Glide® fairing. The chrome-plated brackets serve as stylized mounting points for passing lamp housings and available bullet style turn signals, adding a smooth look that eliminates the cross brace and flat side supports of the Original Equipment installation. Kit includes passing lamp housings, retaining rings, chrome mounting brackets, auxiliary lamp switch and hardware. Auxiliary Lamp Bulbs and Bullet Turn Signal Kits sold separately.
69818-06
IN-STORE PURCHASE ONLY Contact dealer for pricing and availability.
Fits '06-later FLHX models.
MSRP US $299.95
69818-06
MSRP US $299.95
#35
Thanks for the info.... The parts guy could not find this & said I had to order everything individually.
69818-06
MSRP US $299.95
69818-06
MSRP US $299.95
Gully1441
Electrical/Lighting/Alarm
02-08-2015 08:29 AM
karz10
09-17-2012 11:23 AM
