Aux lights on FLHX
RE: Aux lights on FLHX
Custom Auxiliary Lighting Bracket Kit #69818-06
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Add the passing lamp of your choice. I'll be installing Auxiliary Lamp Bulb Kit - Smoked with Lens Optics #68273-03A
Will have the dealer install. [:@]
ORIGINAL: rocknrod
Auxiliary Lamp Bulb Kit - Clear Smooth Lens with Reflector Optics
#68450-04A
#68450-04A
These are 37.5w each, which did tax my old RK's breaker when used with an 85w low-beam bulb. I rewired it using an automotive relay, which worked fine for years 'til I sold the bike.
They also make a 75w variety, which would really produce a bright light, but would also require about 12A that would really tax the 15A fuse. This would definitely require a rewiring, and IMO is overkill. The bulbs on the CC lamps are not replaceable being sealed-beam, but the HD variety also look sealed. On the CC if you break the lens the lamp will need to be replaced. On the HD, it appears to have a sealed bulb inside the reflector, which indicates to me it is not a sealed-beam lamp. Can anyone verify this?
Mine. I don't like the big lights on the SG. I think it takes away from the clean lines. 35W Halogens. Headwinds Rockets and light bar.
[IMG]local://upfiles/26561/649FD02D4A7140F19AB647B6F8BC47A1.jpg[/IMG]
[IMG]local://upfiles/26561/4F93AA54E3514224907399FA5A3ACB9B.jpg[/IMG]
ORIGINAL: johnsonabq
Has anyone put passing lamps on their FLHX using the Custom Auxiliary Lighting Bracket Kit #69818-06? Can you use your existing front turn signals or do they make you buy another set?
Thanks,
Jeff
Thanks,
Jeff
You use the ones on the bike, it does not look like they come off but they do.
It's a fairly tuffinstall if you never had the fairing off and the ignition out. Give your self lots of time on this one.
Use the Service Manual; and, have a slotted 9/16" deep socket for the nut that secures the passing lamps to the bracket--take a cheap socket and grind a 1/4" +/- slot down its length for 1" or so--the power wire from the lamp will get pinched otherwise when the nut is tightened--and only do about 1/2 a rotation on the nut, remove the socket, and repeat until snug.
I'm going to be removing my aux passing lamp kit, visor trim rings, and new passing lamps (HD clear lens with reflector optics) in the next week or two and installing Motolights. I'll list them in the classifieds "for sale" when I do.
ORIGINAL: dowork08
Is this going to be another pain in the a-- installs, ima pro at getting the fairing and all that jazz off so thats not hard....i was hoping it was more plug and play....
And Harleypingman has the facts on the slotted socket.
