Is There a K&N Replacement for SE/AC on 08 Touring Bkies
RE: Is There a K&N Replacement for SE/AC on 08 Touring Bkies
Try here,I think you'll find the part numbers in the thread for stock and SE.
https://www.hdforums.com/m_1496612/tm.htm
Frog13, again, thanks but that thread is from before the 08's even came out and there is no mention of 08 touring modelsand I was under the impression that they are different.
Has anyone replaced their SE element with a K&N on an 08 touring model equipped with the SE/AC kit? What is the parts# and where did you get it? Thanks
Dennis Kirk sells a replacement made by airraid. Made in USA and is oil treated. I have used the Airraid filters in my diesel trucks and the worked excellent.
http://www.denniskirk.com/jsp/produc...0906&mmyId=
ORIGINAL: adlerx
[IMG]local://upfiles/13641/F63176D42CE640EF84BB02022DC11069.jpg[/IMG]
Dawg, is that an 0800? Thanks everyone!
I have an older one that came off my MM bike when I switched it out for carb. It ismaybe less that 1/8shorter though and those bolts threaded for the button screws are just a little to long so it wasn't a tight fit. 95cents at the hardware store and a drill and I'm good to go! Perfect fit and it's a K&N, will last a lifetime! had to redrill 1 hole and cover 2, MM had 4 holes in a rectangle..
Thanks again everyone...
ORIGINAL: adlerx
