Road King fork lock cover
Does anyone have the Kuryakyn fork lock cover? I have RK nacelle on my Shovel and I have the lock covered with a military coin. I am thinking that I may have a piece of plate steel welded to the frame neck so the fork lock actually works. If I did that, the coin would have to go to allow me access to the keyhole.
My thought is, get a cover that swings out of the way and mount the coin to that.
So, here is my question... is it flat or domed? I cannot tell for sure from the picture. It looks flat, but I don't wanna plunk down $40 just to see it up close.
Thanx in advance.
Here is the coin on the bike now. It is at least 1/8th inch thick, so the MoCo cover that lifts up will not work.
Thanx in advance.
RE: Road King fork lock cover
And speaking of grinding, make sure you don't have to grind the edge of your key down to make it work in that cover.
I have a buddy who faced that and swapped over to the Marlin flip-up. While he put a custom insert (modified badge) in his, I liked it so much that I ordered it and use the clock.
...mark
...mark
