LED's Can you "See Me Now?"
Old 05-10-2008, 08:53 PM
Ram's Avatar
Ram
Ram is offline
Default LED's Can you "See Me Now?"
Finally about finished with rear lighting and got the camera with fresh batteries to take pictures.
Have from top to bottom:
LED 11x1.5 Whelen light bar centered in Tour pac.
Back-Off Light by Signal Dynamics for ends of King Tour pac.
H-D LED Tail Lamp with Bar & Shield Logo
H-D Turn signal Brake light module kit
NAPA Truck LED lamps on lower bag guard bars
LED fender light 48 LED's with breaklighting ULTRA BRIGHT, from RideTimeTechnology
Old 05-10-2008, 09:00 PM
Unome's Avatar
Unome
Unome is offline
Default RE: LED's Can you "See Me Now?"
Man, I think Stevie Wonder could see that!!!
Old 05-10-2008, 09:02 PM
thekidnkaren's Avatar
thekidnkaren
thekidnkaren is offline
Sweet, that'll make Ray Charles flinch!
Old 05-10-2008, 09:16 PM
Trapskelly's Avatar
Trapskelly
Trapskelly is offline
Man, that gives "light um up" a whole new meaning![sm=yikesomg.gif]
Old 05-10-2008, 09:47 PM
daharleyrdr's Avatar
daharleyrdr
daharleyrdr is offline
Ram
I like it I want it!! I also have the Ride Time Tech fender tip LED a great product. How about a picture of em off during the day so I can see what ya mounted and how. Also how did you wire them? Thanks Bill
Old 05-10-2008, 10:05 PM
Ram's Avatar
Ram
Ram is offline
ORIGINAL: daharleyrdr
Ram
Finally got the new batteries for the camera today and have them charged. Will see if its not raining to bad tomorrow to pull out of garage and take some day light pictures of how the lower bag and light bar LED's look.You may not like how I've got them installed when you see them close up. But the object IMO is to be seen far off.That I hope is what I've accomplished!
I've taken the Power from the tour pack before the wig-wag for the Whelen LED light bar. Its wired in to the brake lamp ckt. So that is actually off when not on the brake. I wanted the light to be stunning so as to supprise the individual behind me.
The H-D lamps they just wire straight into factory harness. Thats the Bar/shield tail lamp, and the turn signal brake light module (under seat).
RideTimeTech rear fender lamp 48 LED's, that replaces the orignal wiring from behind the Bar / shield tail lamp and plugs in with its own harness to the ckt card behind tail lamp. It has run and brake light all combined and is plug and play. Great item...
Last, the truck LED's I've got them from NAPA auto. They are 3 wires, one ground, run, and turn signal. To keep things simple, I've added a RideTimeTechnology "Trailer / Accessory" wiring break out kit. That provided me the splice points to power the Run/Turn Signals for R/L Lamps on the bag guards. The Trailer/accessory wiring break out was down stream of the H-D turn signal brake light module plug in under the seat. That way the NAPA LED's light up on RUN / Turn Signals Left and Right as well as Brakes and emergency Flashers. If its plugged in upstream of the H-D turn signal brake light module. Then you only have everything minus the "Brake" lights on them.
Thanks for the coments.
Old 05-10-2008, 10:08 PM
flyingace's Avatar
flyingace
flyingace is offline
ORIGINAL: Ram
[ I wanted the light to be stunning so as to supprise the individual behind me.
I believe I can safely say with no doubt what so ever that you have accomplished that!
Old 05-10-2008, 10:28 PM
TideRKC's Avatar
TideRKC
TideRKC is offline
You better be carefulbraking around the airport. Pilots may mistake you for the runway
Old 05-10-2008, 10:47 PM
MikeMihelich's Avatar
MikeMihelich
MikeMihelich is offline
There's another LED product that really helps for conspicuity. HyperLites. They flash very brightly for a few seconds and then stay bright for as long as you have your brakes on. No one ever crowds me when I hit the brakes. the BMW crowd is really into these things. I've had them on every bike I've owned for a while.
Old 05-10-2008, 10:54 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
Damn Nations!
That's some SERIOUS lighting dude!
WOW!
[sm=yikesomg.gif]
Quick Reply: LED's Can you "See Me Now?"
