footboard extenders
RE: footboard extenders
how moutch weight do you really put on they it is a 1/2 bolt they are not a loading platform i never put the weight of more than my foot ???????????????
if it is not harley made in tawain junk they will come up with some reason not to buy it until they sell it than it is GOOD STUFF
I've been using the Kury extenders for a couple of years on two different bikes and have not seen any weakness at all. From time to time on a long ride, I will stand up on my footboards for a few seconds to give my backside a bit of a rest and have not seen any flexing or bending - and I weigh somewhat north of 250lbs...
ORIGINAL: Trapskelly
I'm closer, gotcha by about 50 lbs, no problem with mine, plus .... I have the Soos model. Quick background, I'mnot a degreed engineer, but I do manage an engineering department and work with these guys all the time. I was worried when I ordered them that there would be a lot of stress on the bolt because the old lady steps on the board to throw her leg over. Because of the design of the Soos, I see no difference in the leverage because adding the spacer against the frame with the oval piece below pretty much made it structurally the same as stock. So, I say tell your dealer to go pound sand.
I know I'm smallish....I wasn't breast feed long enough.
ORIGINAL: Kern
You know by gorilla standards, you are a bit on the small side.
I'm a 300 lb. gorrilla and I just rest my size 12's on um.
anubisss
09-27-2009 10:09 AM
TxHarleyGuy2007
05-07-2007 04:13 PM
