Lyndall brake pads...Best deal??
Old 05-09-2008, 03:58 PM
dowork08's Avatar
dowork08
dowork08 is offline
Default RE: Lyndall brake pads...Best deal??
My 08 rear brake just sings you a song when you hit them, sounds like them yoko ono albums i have. I have been really tempted to buy a set of lyndells. I actually talked to them on the phone one day, they said there pads will fix the problem.
Old 05-09-2008, 04:08 PM
lp's Avatar
lp
lp is online now
Received 2,856 Likes on 1,602 Posts
ORIGINAL: spence222
I believe it was 06 and earlier...touring models for sure....not sure about the others. Prob. was corrected in 07.
My 07 did the same thing. And the same solution thing fixed it too! Swapping the rotors around...who knew?!
lp
Old 05-09-2008, 04:09 PM
madmikee's Avatar
madmikee
madmikee is offline
FastHarley at motorcyclemetal doesn't sell Lyndal anymore.
I went direct to Lyndal's web site.
Old 05-09-2008, 04:14 PM
mtairy biker's Avatar
mtairy biker
mtairy biker is offline
I have them on mine and my wifes bike last i checked try hog pro for the best price
Old 05-09-2008, 06:19 PM
az232's Avatar
az232
az232 is offline
I tried the Harley fix with the rotor switch. It was only a temp fix. Squeal came back. Had my indie mechanic put on Lyndalls when I took the bike out storage a few months ago. Squeal is gone for good. I still get a little brake dust but not anywhere as much as I used to (my bike is white so brake dust is a pain in the ***). I highly recommend the Lyndall pads.
Old 05-09-2008, 06:23 PM
anubisss's Avatar
anubisss
anubisss is offline
www.cyclespot.com has good prices.
Old 05-09-2008, 10:49 PM
gbslane's Avatar
gbslane
gbslane is offline
Cycle Spot.....
Old 05-10-2008, 08:57 AM
captsam54's Avatar
captsam54
captsam54 is offline
Yep.. My 08SG squealed at the rear every time I braked.. Finally got Lyndall's.. and no more noise..!!
Actually...... My brakes do make noise now.. Before, I could apply the brakes and the rotors, and hydraulic braking system would just stop the bike.. No noise.(except for the sometimes squeal)
Now after changing the rims, new Avon tires and Lyndall brake pads.. When I apply pressure to the ft. or rear brakes. I get the familiar Harley brake rotor sound..
Still can't figure it out..
Old 05-10-2008, 09:27 AM
Spartan's Avatar
Spartan
Spartan is offline
I went with Performance Friction. It easy on the rotors, no fade, good biteand they last longer.
http://www.performancefriction.com/pages/cycles.htm
The Borg
07-14-2023 10:18 AM
Chuck1
06-23-2017 12:36 AM
Rollbar
02-03-2015 07:29 PM
DougsDyna
04-08-2008 12:20 AM
MAX EVO
10-26-2007 09:52 AM
Quick Reply: Lyndall brake pads...Best deal??
