stock sg seat with the harley backrest
Old 05-07-2008, 09:18 AM
Frankie-FLHXI's Avatar
Frankie-FLHXI
Frankie-FLHXI is offline
Default stock sg seat with the harley backrest
Anybody using a stock sg seat with the harley backrest? is yours set to far forward? i can't get mine to angle back enough to be comfortable. anybody with any input?
Old 05-07-2008, 07:29 PM
Pat's Avatar
Pat
Pat is offline
Default RE: stock sg seat with the harley backrest
I have a back rest with the stock SG seat and don't have a problem but I'm not very tall so I appreciate being a bit closer to the bars. Some on here have had success with bending the seat post back a bit to get more room or a more comfortable angle.
Old 05-07-2008, 07:49 PM
Jinks's Avatar
Jinks
Jinks is offline
I had a similar problem with the backrest on my Road Glide. I removed the strap that mounts from the front of the bracket under the seat to the frame & made a longer one. Then I bolted the bracket tab on top of the new strap. That allowed the backrest to tilt back far enough that adjusting the set screw made it comfortable. Take a look at the mounting setup. Might just require a little tinkerin'.
Old 05-07-2008, 08:16 PM
shortleg's Avatar
shortleg
shortleg is offline
I got myself a Mustang back rest and it works better than the
ones from Harley.I had both and they both were not for me
shortleg[Dave]
Old 05-07-2008, 08:19 PM
Scootr's Avatar
Scootr
Scootr is offline
I put a few washers/spacers under the front of the mounting bracket to move me back. It was just enough to make it perfect for me.
Old 05-08-2008, 05:09 AM
Frankie-FLHXI
ok all sounds like good advise ... i'm thinking of bending the post first.. anybody else have any thoughts
Old 05-08-2008, 08:06 AM
Frankie-FLHXI
bent the posts .... easy fix .... thanks all
Old 05-08-2008, 09:01 AM
spankustang's Avatar
spankustang
spankustang is offline
Put mine in a vise and bent them. Took a few tries. But now it's perfect. I'm 6'2 and when I first put it on, it felt like I was 7' tall!!!!
Old 05-09-2008, 12:50 PM
Frankie-FLHXI
ok anybody else with this problem just bend the bars ....worked great!
Old 05-09-2008, 01:36 PM
achog88's Avatar
achog88
achog88 is offline
I put the bend of the post in the shop's hydraulic brake and increased the angle and the problem is fixed. Now it doesn't push me forward as much and I can lean back to a more comfortable angle.
However, I think the post is too long. I don't like the big gap it leaves between the seat and the bottom of the backrest. I also think there is too much slack between the post and the bracket, the backrest rattle around. Anyone find a solution to those problemsyet. BTW, my seat is a stock SG seat.
Quick Reply: stock sg seat with the harley backrest
