80W-90 Gear Lube...
80W-90 Gear Lube...
Getting ready to change oil in my trans this week...Went to local shop that sells Amsoil to get aquart ofAmsoil 75-90 SVG (from my understanding Amsoil fans use this in their trans). Asked for that and the guy didn't have it, what theydid have is Amsoil Gear Lube SAE 80W-90 and he said that was what I needed...is that ok to use or should I look elsewhere for the 75-90 SVG???
RE: 80W-90 Gear Lube...
I'd go to the Amsoil website and look up that particular oil to see what it's application is. Maybe it's OK if it's got the right API rating. If you live in a hot climate then it may be better for you than the other, though I doubt 5W makes any significant difference.
ORIGINAL: bigbean78
Their site catagoried the 80W-90 with the other 3 severe gear fluids...they recommend the Severe Gear75W-140 for the Harley six speed trans to help quiet down the fifth gear whine...hmmmm, I may take the 80-90 back and look around for that 75-140.
ORIGINAL: bigbean78
Well, I decided not to use the 80W-90...found a local independent auto parts store that carries Amsoil products, but the didn't have the Severe Gear [:@]. They had Royal Purple 75W-90 and 75W-140 Synthetic Gear Lube...decided to go with the 75W-90. Now, is the 90 lighter weight than the 140? I assumed the 140 was heavier, and living in southeast MI figured the 90 would be fine...Any pros or cons to the 90 and 140?
The AMSOIL 80W-90 is just fine. The only reason they make it is for those manufacturers that call for an 80W-90 gear lube and people want what the owners manual says. It actually is a 75W-90 gear lube when they test it. Esentially the same stuff with a different label. That was a nice piece of info I received at the last sale meeting
python33 (06-16-2022)
amervtwin
02-20-2009 07:00 PM
