Expected Life of a Typical Dunlop Rear Tire/Michelin
RE: Expected Life of a Typical Dunlop Rear Tire/Michelin
Amost 11,000 on the OEM rear. Ordered the new MU85 Michelin Commander.
Ran Elite 3's on my Shadow for years. It lasted longer because it was a Gold Wing tire with heavier compound. Maybe if it was a softer compound it wouldn't have broke loose in the curve.
I have no idea how you guys are getting >10k on stock D402's. I ran two of them to 10k with barely any tread at all in the end, and have even taken steps to reduce rear tire wear. For one, I am not an aggressive rider, don't do much interstate travel, keep pressures at 40psi cold, and never use my rear brake unless necessary. This should assure good mileage, but I have not realized it on the D402's.
In response, I've gone to another option on my third rear tire: Dunlop Elite 3. It was originally designed for Gold Wings, whose owners were complaining about low tire mileage, and have been getting rave reviews for durability and performance, both in the wet and dry. I mounted an MU90-16 bias version 3k miles ago and can say that wear is definitely improved, showing little wear up to this point. I sense no difference in performance over the D402, although I did have a stressful moment last week when I hit a yellow lane divider strip in the rain. In a curve, the bike slipped, then grabbed, causing no damage or accident but a very tense 1-2 seconds as I wrestled the bike back into control after some fishtailing. I think this was not a tire issue, as I've squirmed before on paint strips, although not quite like this one. It was after the rain had just started, thus oil on the road was not fully washed off, in a curve, and under light acceleration. I was going slow, but I'll chalk that one up to me not observing due caution in a risky situation, not the tires for faulty traction. After 41 years of riding you'd think I'd know better.
ORIGINAL: iclick
Glad to hear you kept her under control! I'll be looking for your post once you go thru that Elite 3. I almost got those instead of the Commanders.
Yeah, I dunno how lots of people are getting 12k+ out of the 402's either. Only think I can think of is a combination of conservative riding and very smooth surfaced roads (maybe cooler weather also?).
bulldogmoe7, that line running across the tread is the wear bar. When the tread is so worn down that that wear bar (slightly raised line) is even with the rest of the rubber on the tire...it is time for a new one.
10-12 thousand seem typical of what i have seen, also i have heard nothing but good about the lyndall pads. I am half temped to buy a set for my 08 rear since the pad on it do nothe but squeal and i have taken it in for the problem and the dealer puts its majic squeal be gone wash on it. Thats does not work. So i may be going also with a set of lyndells
