A sign of heat...normal?
Old 05-02-2008, 03:06 PM
Akitakoi's Avatar
Akitakoi
Akitakoi is offline
Default RE: A sign of heat...normal?
ORIGINAL: ultrarod
Akitakoi.....what is IDS ?
Isolated Drive System, fix's the "Clatter" "Rocks in a Can"noise on 07's. Comes stock on 08's.
  #32
Old 05-02-2008, 03:10 PM
FLHT's Avatar
FLHT
FLHT is offline
Even with the stage one download you are still running lean. Lean = HOT
  #33
Old 05-02-2008, 03:41 PM
Bluerose
Guest
Posts: n/a
Anyone have an actual copy of the 2 year warrenty? I know what the extended says but I have never seen a copy of the 2 year.....they don't give it to you with the bike I've had 2 and no warrenty info for the 2 year was ever given to me....the dealer just keeps spouting out "that will void your warrenty".
  #34
Old 05-02-2008, 04:54 PM
harleykris's Avatar
harleykris
harleykris is offline
I put a PCIII on mine while it was still under warranty. Anytime I needed warranty work done, I just took off the PCIII and brought the bike in. They never new I had one on.
  #35
Old 05-02-2008, 06:31 PM
binkman78's Avatar
binkman78
binkman78 is offline
Heat issue???? http://gizmodo.com/photogallery/unobike if that thing had a Batwing on it & HD logo- I'd ride it.
  #36
Old 05-02-2008, 06:50 PM
rick180's Avatar
rick180
rick180 is offline
Hey Bluerose, put the one inch soos extentions on your bike, that will move your leg farther away from the exhaust. It will help some.
  #37
Old 05-02-2008, 09:45 PM
blueride's Avatar
blueride
blueride is offline
The heat on my 08 stock RG was getting to me also. I tried the niterider's 02 IED's and was pleasantly surprised at how well they worked at reducing engine heat and improving performance.They work so wellthat I'm keeping the stock pipes and air cleaner.No plans for a fuel management system either. I've owned five Harley's and have modified every one of them, this one I'm leaving alone.
For a stock or stage 1 bike, the IED's are hard to beat.
  #38
Old 05-02-2008, 10:50 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
ORIGINAL: Bluerose
My factory warranty is in my owner's manual on my '06.
  #39
Old 05-02-2008, 10:55 PM
electraride2's Avatar
electraride2
electraride2 is offline
true duals..........the only way to fly
  #40
Old 05-03-2008, 02:34 AM
Ram's Avatar
Ram
Ram is offline
I'm still trying to figure out the milky chrome! Is this a new thing with the '08s?
I've never seen mine like that! Its been dirty and on the verge of corrosion! Milky?
Are the front fork down tubes pitting yet?
Quick Reply: A sign of heat...normal?
