SE 6 speed
RE: SE 6 speed
I went for the whole SE Stage Three but just the SE-211 cams. I got the HTCC heads, intake and pistons. Running 10.5:1 so I had to get the comp release. Pain to remember to push them when I first got it done. Starter really moans if comp releases are closed. Power commander. Tried a set of used Rhineharts but got more HP from SE Slip ons. So I stayed with them. Picture in my sig is before kit and gears. I need to take a new one. Bike has been on dyno several times to get the custom map just right. Not sure of all the Mechanic did tweaking the bike (he is a good friend) but he told me that a few more ponies are in it but I wanted to keep it rideable.
RE: SE 6 speed
Thanks for the info. I guess that .89 to 1 final drive really drops the rpm out of the power band. I usually run about 80 and motor is in its zone. I even get 40mpg if I play nice. Oh and to all. I put the new picture in my sig. 6 speed cover sure is shiny and really stands out different than stock.
RE: SE 6 speed
ORIGINAL: dyna95th
Thanks
Thinking of going with a custom bump stick that Branch has to offer, along with their port work. I hope to be close to the 100/100 nark with my 95
RE: SE 6 speed
Thanks for the input from all. I have been experimenting some with the new tranny. For normal short runs I almost never hit 6th. Once on the freeway or open road this baby hums at 75-85 all day and I get great gas mileage. At that speed the motor is in the groove. Best mod I ever went with. Little expensive but worth every $$$$$$.
RE: SE 6 speed
My curiousity has kicked in:
what are your RPM's @ 80m/h in 6th gear?
What are the RPM,s @80 m/h in 5th gear on a 5 speed tranny?I would know but I dont have a tac on my road king although I hear the motor screaming so I sometimes forget Im in 5th gear and try to shift up 1 more gear(thinking dam I wish I had a 6 speed)
