Headlamp visor trim ring install question?
Old 04-30-2008, 10:46 PM
Hog Heaven's Avatar
Hog Heaven
Hog Heaven is offline
Default Headlamp visor trim ring install question?
How many of you guys have installed one of these and did you actually get the accessory trim ring to fit tight all the way around the original trim ring? My parts guy said (as did the instructions)that the accessory trim ring fits right over the existing trim ring but I can't for the life of me get the accessory trim to snug up the gap at the bottom of the trim ring. I've got about a 1/4 inch gap or so, does that sound right? Oh yes, it's going on an '08 FLHR.
Old 04-30-2008, 10:48 PM
MikeB's Avatar
MikeB
MikeB is offline
Default RE: Headlamp visor trim ring install question?
Same thing with mine and everyone else I have seen.
Old 04-30-2008, 11:10 PM
Hog Heaven's Avatar
Hog Heaven
Thanks for the quick response Mike. Do these things rattle at all? I'm going to be pissed if I just spent $40 to have a headlamp that rattles and annoys the crap outta me. My old Roadstar was good at that.
Old 04-30-2008, 11:13 PM
drfeelgood's Avatar
drfeelgood
drfeelgood is offline
Check this link out, another thread regarding this topic.
https://www.hdforums.com/m_3293444/tm.htm
I was able to get mine close to being snug, took some work though.
Old 04-30-2008, 11:17 PM
wglide69's Avatar
wglide69
wglide69 is offline
Seems like there is plenty of chatter out there about this subject. Some seem to have gotten the gap to close by loosening the stock trim ring holding screw then slipping the new trim ring over and snugging it up then snug up the other screw a bit.....and finally they got the gap to close. I tried everything and must have had the visor trim ring on and off a dozen times. Funny thing is, if you take them both off and the new visor ring does not completely fit around the stock ring so I'm not sure howit can be done. Maybe it is possible that not all of these visor rings are the same diameter but thatseems unlikely. I ended up with a bit less than a 1/8" and can live with it. So you guys are not alone with this problem.
Old 04-30-2008, 11:33 PM
WingIt's Avatar
WingIt
WingIt is offline
Yup I've got a 1/8" gap also and I'm not crazy about the cheesy phillips head screw seeing you have to get it so tight to close the gap. I had visions of a screw driver going thru my hand.
Old 05-01-2008, 12:33 AM
YodaddyKeith's Avatar
YodaddyKeith
YodaddyKeith is offline
Mine fits perfect, but you must do this:
Remove old ring and toss in trash
Bend rim of headlight bucket outwards in 5-6 places with visegrips
Install new ring...it will fit nice n tight and the gap will be seamless.
Old 05-01-2008, 11:35 AM
Big Peter's Avatar
Big Peter
Big Peter is offline
ORIGINAL: WingIt
thru the stealers head [:@]
Old 05-01-2008, 11:39 AM
Scott_WI's Avatar
Scott_WI
Scott_WI is offline
I had a big gap too, so what I did was took off the internal ring, used my dremel and cut out 1/4" from the internal ring. Put it back on, then put the visor ring on, and now I've got a very tiny gap, much better.
Scott
Old 05-01-2008, 01:21 PM
Main Monkey Business's Avatar
Main Monkey Business is offline
Same problem here. Tossed the original ring and padded the new ring with weatherstripping and tightened it up. Fits fine and no rattle.
Quick Reply: Headlamp visor trim ring install question?
