Ethanol
#31
ORIGINAL: rochkes
Keep in mind that it is legal for a gas station to post "contains no ethanol" on a pump that has less than 10% ethanol. So lets say your down at Casey's and one pump says no ehtanol and one says 10% ethanol, it is legal for one to have 9.9% ethanol and the other to have 10%.
Ammoco is the only gas station I know of in this country that ALWAYS has pure gas.
Dennis
Dennis
#32
ORIGINAL: TN Houndog
Building the refinery is the EASY part. Getting the permits to build it is something else. With all the roadblocks and regulations the EPA and the enviroidiots have put in the way, is it any wonder we're in the shape we're in? I'd like Bush or whoever his successor is to call a national emergency for fuel and suspend the whole regulatory process! I'd bet we could put a new refinery online in less than 2 years without all the regulatory BS. The same goes for the oil wells.
ORIGINAL: SG 1
Do you know how long it takes to build a refinery? This country (WE) need to start now!
There's a company trying about 75 miles from my house, they are gaining ground but at the rate they're going with everyone around the area bitching, it's gonna take years to get approved. [:@]
#33
ORIGINAL: FX4
Wong-O-You don't even know what refinery or pump station it is coming out of. Your Amoco at the pump could very well have been refined at a Sunoco plant. You just can not tell by brand. The only thing you can be certain of is that whatever additives are advertised by a brand are in the gas.
ORIGINAL: rochkes
Dennis
Dennis
But I do know that at least before it was BP, Amoco GUARANTEED no ethanol in their gas.
Dennis
#35
ORIGINAL: rochkes
I am not going to argue or pretend I know all about this, but a friend of mine owns an Amoco station. I am just going by what he tells me. Then again, I guess they call themselves BP now and maybe their policies have changed or maybe they never did have the exclusive that my bud says they did.
Dennis
ORIGINAL: FX4
ORIGINAL: rochkes
Dennis
Dennis
Dennis
1. All refiners blend and make fuel to a certain specification that is all pumped into the same supply pipeline. Additives are added at the delivery truck.
2. There are a couple of refiners in the area that supply all gas stations no matter what the brand is. A given load just gets different additives.
3. Or in the case of Florida it is sent in by ocean freighter.
You are talking about the days when ethanol ruined cars - almost twenty years ago.
*** I should also add that I do not know where in the supply chain the ethanol blending occurs.
#36
#37
#38
#39
I've stored every bike I've owned over the last 14 years on ethanol blend, but I do add the Yamaha fuel conditioner (I like it better than Stabil). And they are usually stored for close to 6 months. Never had a problem starting or running on the old gas in the spring. Again...I don't agree with the use of Ethanol....but its not going to hurt your bike, at least at the 10% mixture.
#40
Well, life long Iowan here. I know a thing or two about corn you could say. LOL
First of all I do run ethonal in my bike if I have to, still 93 octane, runs fine but loses 1 or 2 mpg.More if you run hard.
I had a Tahoe that within 5 miles of putting it in the tank, the engine light would come on and missfire.
The ethanol acts like a solvent and will clean out varnish and carbon build ups. This can foul plugs, carbs and injectors. I think if you start running it when new or newer, shouldn't be a problem.
Since we are crossing into the political thread it seems, lol - true, ethanol takes more petroleum energy to produce than it yields. BUT, it is renewable. AND, when the petroleum used to produce the ethanol is slowly converted to alternative fuel sources, the carbon footprint will shrink. It will be more efficient to produce. BUT - think about it, if less corn was needed for ethanol since it is so un-attractive to so many,that acreage would be switched to producethe true bright stars of our future such as soybeans (bio-diesel), switch grass (ethanol) and even sugar cane (ethanol) were sustituted. There would still be a "food shortage". That's the trade off for renewable fuels. There's no easy way out of this guys!
So burn what ya burn, just keep riding!
U
U
nevada72
Road Trips
20
10-28-2018 08:33 AM
