'08 RKC Bars - Wild1 info
This may be repeat info for some, but it seemed new to me so I thought I'd pass it on. I've been scrubbing the boards for info on replacement bars for the '08 RKC I traded in my Sporty on a couple weeks ago. The bars are rough on the back as most seem to think. So I need a replacement.
It seems the pickings are super slim on bars that will work with the TGS on the new RKs, and the dealership wanted to charge $200 for a couple hours of fabrication to make other bars work with it. Too much for me.
Looking through all the posts here it seemed like folks were pretty happy with the Wild1 Chubby 508 and 518 bars, so I called them to get more info. The guy I talked to said "Tell your dealer that all of our bars are being shipped already notched for the TGS so they work just fine on the '08 RKs" So, there you go. Was news to me, thought it might be news to others. My bike does NOT have ABS btw, so not sure if that makes a difference. Here's the bar he recommended along with my stats:
Me:
5'11
172 lbs
Recommendations:
- Wild 1 518 bar (thought 508 would be uncomfortable for my size due to too much pull back) ($220)
- Wiring Extension: 2007 and up bagger model +8 wiring for switches (from www.Namzccp.com) ($37)
- No extension needed for TGS, they have plenty of wire in there already
- No cable extensions needed
- Roughly a 4 to 6 hour job to make the change. 4 for a dealer, 6 for me.
So, once I get back from a trip to the UK and Ireland next month, going to pull the trigger on this upgrade (if I have any cash left thanks to the sh1tty US dollar). Should come in under $300 bucks, assuming I don't break anything. Hope the info helps others! And thanks to all that helped guide the research through their posts...
Me:
5'11
172 lbs
Recommendations:
RE: '08 RKC Bars - Wild1 info
I was asking specifically about those models, so I can't say for sure. I would guess it's only the bars specifically for the RK's, as the others likely wouldn't need it, but that's just a guess. Might want to give em a call...they are super helpful on the phone.
Hey guys, I'll do you one better. Contact wild1hd he's a member on the forum and you may have even talked to him when you called Wild 1. His name is Johnny and he works for Wild 1, and sells Chubby bars and cables and at better prices.
Wild 1's has many of their bars, if not all, set up for the 08 TBW. If I didn't have ABS, I would have went with Chubby bars. Didn't want to mess with the ABS line right now. You guys without the ABS are set, many bar possiblities.
Good luck!
Good luck!
It's not really a hard job with service manual.
Have fun.
I've thought about doing the braded cables as well, but man...as it's a new bike I need to be a bit conservative on how much I'm spending. Still need to do stage 1. Any idea how much extra it would be if I added cables to the equation? It would just be brake and clutch, correct? How much complexity does that add to the project?
I just put a set of 515 Wild 1 on 05 RK custom and I love them,They are 10" apes.No extenders needed on anything except the wires I put inside the bars,Man these clean up the bars good.All switch and horn wires are hid in the bars now.They feel great to.36" wide I think sure feels better than those pull back wheelbarrow bars.Hope you find what you want.
Hey fellows I also have an 07 RKC, I installed the wo518 bars on mine, You,ll love them, Like Stuke above,I went4 inch over on the throttle,idle,clutch and brake,evrything went in great, I believe08 models have MOLEX connectors also like 07, I bought all my stuff from a place called cyclespot.com, bars and magnum chromite cables and lines,as far as wiring in the bars, I bought a kit from NovelloCreations, its a wire extension kit plugs right into your harness,simple good luck. and enjoy the RIDE
