Major Problem with my NEW 08 Roadglide
Old 04-28-2008, 06:16 AM
blueride's Avatar
blueride
blueride is offline
Default RE: Major Problem with my NEW 08 Roadglide
Yeah, I noticed on my 08 Roadglide that the bars and the instrument cluster are cocked a few degrees to the right. I'll try that guy's suggestion of locking the forks and trying to straighten it out.Dealer wouldn't do anything.
It definitely pisses me off every time I ride down the road and look at it.
I'll try looking over the tank at the front forks like you did.
Old 04-28-2008, 06:25 AM
rjgraham's Avatar
rjgraham
rjgraham is offline
Dealers suck, go to to private shops that care about you and your bike. I go to the dealer to BUY the bike and for t-shirts. I order everything else online and use custom speed shops that have 1/2 the labor rate of the stealership.
Old 04-28-2008, 08:52 AM
rideon's Avatar
rideon
rideon is offline
ORIGINAL: blueride
My new roadie is the same, bugs the hell outa me. The gauge cluster to the fairing is not parellel, once you know you can't stop looking.[:@]
Old 04-28-2008, 09:48 AM
jwm6's Avatar
jwm6
jwm6 is offline
Same problem on my 08 RKC, dealer said it was normal[:@]
They finally checked the alignment and found it was out of spec, anyway the bike still pulls to the left. I haven't be back to them yet, it just makes me mad when they try to bs me.
Anyway good luck, let us know what happens.
Old 04-28-2008, 01:54 PM
Peppa1's Avatar
Peppa1
Peppa1 is offline
I would suggest you do the following:
Loosen the bolts on the bottom holding the handlebar clamps and twist the bars to get them lined up correctly and then have someone sit on the bike and hold the bars firmly as you tighten them back down. These things use handlebar riser bushings and they do flex if you tug on the bars. You can get some aftermarket ones that are made of a much stiffer compound.
Old 04-28-2008, 02:36 PM
smokindave's Avatar
smokindave
smokindave is offline
Well lets see if I can make some sense of your potential problem. There are two alignments you need to make sure you have, the front fork tubes and the back wheel.
Front tubes- The upper and lower triple trees must be aligned. It is possible the bottom and top trees are twisted, with the tubes not parallel. This is fixed by loosening the trees and bringing them back to parallel. There is a spec that HD probably uses to bring this into alignment, I do it with magnetic straight edges. It does not take much to make the frontend seem out of line and this will also give the sensation of pulling to one side as you describe.
Rear wheel alignment - This is crucial or you will have the sensation of the rear wheel "dog tracking" to one side. This has a different feel than the front alignment problem above. It is possible for the handlebars to be straight and have the rear dog tracking. This does not sound like your problem though. But, this is how you check....If you have a line cut on your driveway or just mark in chaulk a straight line and then pull the bike onto the center of the line. Now ckeck to see that both front and rear wheels are centered on that line and they should be. If not your rear wheel adjustment is off.
Lastly, it is possible the handle bars are just twisted in the bar clamps and need to be loosened and straightened. Yes, Peppa1 is correct also about the riser bushings also. Remember to loosenthe riserbushing bolts when you loosen the bar clamps and realign together.
Warning - I would not tug on the handlebars with the steering lock on, because you will actually break the lock. This is how thieves steal bikes, they just snap the steering lock.
Old 04-28-2008, 02:44 PM
bigtone's Avatar
bigtone
bigtone is offline
I agree with the above, do not put force on the bars with the forks locked. It is an alignment issue, and as mentioned above push the dealer until the solve the problem. Should go straight as an arrow if it was aligned correctly. Left side drive does not cause a pull, neither does the primary hanging on the left. I built a Kenny Boyce pro street with the primary 3/8 offset for additional tire clearance and it tracks perfectly straight.
[IMG]local://upfiles/48173/8B08A76815B8472D96524E802E29A729.jpg[/IMG]
Old 04-28-2008, 04:01 PM
88b's Avatar
88b
88b is offline
I'll second DO NOT use the steering lock to hold the trees while you force the bars, it will break. On all baggers the motor trans and swing are are all supposed to be aligned, now we all know how much care HD take during production and the dealer always checks everything is correct before the customer takes delivery [sm=trust_me.gif]. So there is a good chance the back wheel isn't parrell to the frame, smokindave's idea about the line on the driveway is a good way to check.
A guy i know in Ormond Beach Fl has the same problem with his new 08 RG. Strange that a lot of 08 RG's have this problem, or is something wrong in production ?
Old 04-28-2008, 08:30 PM
seawolfhd's Avatar
seawolfhd
seawolfhd is offline
It seems to me some where it says another way to checkfront and rear wheels is with a long straight edge, have someone stand the bike up and run the straight along both wheels, I'm going to try this over the weekend to check the rear wheel.
Old 04-28-2008, 09:02 PM
dowork08's Avatar
dowork08
dowork08 is offline
my 08 SG drifts to the left also....kinda weird since none of the other bikes i have had have done that. But oh welll its a awsome ride
Quick Reply: Major Problem with my NEW 08 Roadglide
