Oil Cooler with Center Stand?
I have a 2005 Ultra with a front Center Stand that I installed from Harley Davidson. I'd like to install an oil cooler, preferably the Jagg 10 row horizontal lowmount cooler that install under the voltage regulator.
I'm not sure if the center stand will interfere with the oil cooler. Any suggestions?
There is a center stand (91573-06) and a display stand (99002-97A)
According to the HD catalog there is a warning that you can not use the display stand with the oil cooler which is mounted toward the front wheel. The center stand has adjustable feet that allows for low suspension and mounts toward the rear wheel.
It appears you have the display stand that interfers with the mounting of the oil cooler.
jim
jim
