Removing Broken Detachables Lock
Put the detahcables lock on my tour pak and really messed up...I followed the directions. I know,I know.
Now I put the tour pak on locked the lock and the key is about 1/16" too long. So trying to getthe key in to unlock it I broke the little button of the lock. Now I can't get it to unlock so I can't remove the tour pak.
Anyone have any ideas how to get this thing unlocked? Before I take the whole pak apart to get to the lock and drilll it out.
George.
George.
Take the saddlebag off the side youir broken lock is on and then you'll be able to see the bushing that the locking lever is on. Take the bolt out of the bushing (the bushing will now come off with the locking lever) unsnap the other side and remove your tour pack, your key might still work to unlock it, the button is only to engage the lock if I remember right. I hope this helps
Let me know how it turns out.
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
Try what gilbos said. Once you get the Tour-pak off, maybe you can turn the shaft of the lock with a needle nose. If that don't work, you can try to cut the shaft of the lock (down by the detach bushing) off with a Dremel.
And what Bluerose said, I bent my "key" to about 90 degrees so it would go on and off easy. I unlock it from the rear, some unlock from the side through the hole in the plate.
ORIGINAL: Bluerose
You needed to bend the Key....if you put a new one on just take a couple of box end wrenches (if you have nothing else) and bend the key 15 - 30 degrees.
As you found out the locks are pretty touchy.[&:]
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
I don't know what I was thinking yesterday It never dawned on me totake the bushing off like gilbos440rtsaid. I removed the bushing today, I still couldn't get the lock to open and could not rotate it to drill it out. But with the whole thing off I was able to get a pair of channel locks on it and squeeze really hard and force the lock to release, the key was in it.
Thanks everyone for the help.
I'll need to get a new lock now if I want to have it secure. I just bought that two days ago
![Frown](https://www.hdforums.com/forum/images/smilies/frown.gif)
Thanks.
George.
ORIGINAL: Bluerose
You would think harley would know about the issue....the dang keys barely fit the sissy bars and are always a problem with tour packs.
Glad you got it worked out.
George.
