PIAA lights for Running Lights
RE: PIAA lights for Running Lights
Hey CD - Slick ride, and nice lights, but no. I'm looking for a better bulb for my stock passing lights. I've read of replacements for the headlamp but wanted to know if anyone has replaced their stock 35 watt passing lamp bulbs with a PIAA bulb or other brand.
Thanks
Thanks
If you have not used the Search feature, follow this link.
https://www.hdforums.com/m_2939044/tm.htm
Thanks to HarleyPingMan
Good Luck
Good Luck
When I converted mine over...Piaa was not making a replacement bulb for the passing lamps...I was however able to find automotive bulbs that plugged right into the connector from I think it was autozone or advance autoparts...they were a xenon gas bulb 26 watt I think...(the same wattage as stock...did add the PIAA headlamp bulb and let me tell you...with high beams on it's like riding in the daytime...just not as warm as with the sunshine on you...damn it's bright...
I bought the HD halogen replacement passing lamp set and used a razor to cut away the rubber boot on the back& removed the stock bulb unit. A trip to walmart to pick up 55w replacement bulbs, ten more minutes putting them in the lens, & a little rubber cement, the job was done. Really lights up the night. I've also rigged the passing lamps to stay on with the high beam, instant daylight.
08ClassicRider
Electrical/Lighting/Alarm
15
06-17-2019 09:18 PM
lunloon
03-01-2010 01:59 AM
bulbs, davidson, halogen, harleydavidson, harly, king, lamp, light, passing, piaa, replacement, reviews, road, running, streetglide
