Amsoil ? in all three
RE: Amsoil ? in all three
Harley Screaming Eagles have the same weight synthetic in all three holes from the factory. I however changed to Amsoil. I run 20/50 in the engine and main chain case and Amsoil 75/90 in the transmission. This is why. Because the transmission is lubricated by the gears in the lower case carrying the lubricant up to the upper gears. The heavier oil the better itās carried up to the other gears. The heavier oil coats the surface of the teeth better. The gears as they mesh and release is where friction is most prominent. A lubricant that has a better build up and having a better pressure rating will resist friction better at this point. This is why I run the heavier oil in the transmission.
[IMG]local://upfiles/47469/0E94F28995C943D8BEE885D0E13DF0F9.jpg[/IMG]
I have a 2007 FLHX and had some of the tranny noise
then started to use amsoil
I run the 20/50 in all three holes, and it quieted down a sicnificant amount. i live in Iowa and have a few cool mornings and hardley any really hot days. If i lived in the southern part of the us I would probably install the heavier gear oils in my tranny as some of the other guys have suggested. just my opinion.
Ride today,for we don';t have tommorrow,I am a Amsoil Dealer from Louisiana.I run Amsoil in all my componubts of my bike 2001 FLHT.also I have a construction co,with 12 RD688 Macks that all run Amsoil.let me tell you bout amsoil i ran it for 40,000 miles in a mack had it samplled it came back exceptebile to continue service.Also you can ride your harley in parade's without having to shut it down,Amsoil will cover you it takes the heat better then anything I've ever seen,including lucus product's.If anyone that rides would like to try Amsoil,I have a special cost plus10% deal I give Harley bro's. Buck McDonald
Amsoil#1127755
mic2200384@aol.com[&:]
Amsoil#1127755
Ace07FXDL
Oil Archive (no new posts)
11-04-2007 04:24 PM
