Lights on with ignition on acc.Help
04-23-2008, 12:30 PM
I have a 02 Road King and I noticed that the lights are still on when the ignition is turned to the Acc. position, any thoughts?
04-23-2008, 12:34 PM
RE: Lights on with ignition on acc.Help
same as the last 3 harleys i have owned
that is standard
04-23-2008, 01:11 PM
Just the auxilary lamps or headlamp too?
On my 07 RK, the auxilary lamps stay on with switch in acc. - not the headlamp - but that's because I did the wiring mod to keep them on with my high beam. Easy answer for me is toggle them off. And not an issue anyway since I have nothing on acc. circuit anyway.
04-23-2008, 01:14 PM
FWIW, on my '03 EGC no lights (taillight, headlight, turn signals, passing lamps) are on with the ignition switch in acc position.
04-23-2008, 01:30 PM
I need to know what to do to keep the headlights off on acc. because I just added a radio and I dont want the lights on when the bike is turned off.
04-23-2008, 01:36 PM
On my EG, the only light on is the speedo. Check the wiring diagram in your manual.
RANGER73
Electrical/Lighting/Alarm
03-24-2017 07:07 PM
jlbreaux
07-09-2013 07:00 PM
D1gger
EVO
20
07-04-2011 07:03 PM
Puggy
04-17-2008 01:03 PM
brian.yerich
11-14-2006 11:16 AM
