nitrogen in tires
Old 04-21-2008, 09:53 PM
TexasRedneck's Avatar
TexasRedneck
TexasRedneck is offline
Default RE: nitrogen in tires
Ya'll do as ya will. Bear in mind that in my li'l workshop is 2 drill presses (floor an' bench), 1 vertical band saw (wood), 1 horizonal band saw (steel), 1 cabinet saw, 2 mig welders (110 & 220 vac), 1 stick welder, 1 oxacetylene rig, 1 table lift, 2 air compressors....an' more tools than most have. NONE of it is cheap stock - most of the power stuff is from Jet, Lincoln, Esab, etc. - so I don't mind spending money if/when needed.
That said, I wouldn't go 500 feet to get nitrogen in my tires - period. Just see no *real* need.
Draggin' Baggers wuz one of them companies that snuck into this forum by settin' up a deal with another forum member whar he'd git "bennies" from every forum member that bought. When the kits they hawked (for lowerin' bikes w/air shocks) started damaging the bikes, they skedaddled quicker'n a Boone & Crockett buck on openin' day!
Old 04-21-2008, 11:18 PM
CoyoteJoe's Avatar
CoyoteJoe
CoyoteJoe is offline
When the kids and I played paintball, you could get CO2 or nitrogen to charge the tanks, and nitro was better cause it didn't freeze up in rapid fire (we had some wicked paintball guns). I talked to the fillers, and discovered they made they own nitrogen with an air compressor and a really good water vapor trap that took all the moisture out. I wonder what your getting for the seven bucks, and I can't see a little water vapor and impurities (oxygen, hydrogen, etc) making a difference. Just my two cents...
Old 04-21-2008, 11:24 PM
jdtest's Avatar
jdtest
jdtest is offline
Just put air in it. At work I have an endless supply of nitrogen, but it much quicker and more convinient to check put air in it everytime you fill up with gas.
Old 04-21-2008, 11:30 PM
mbmike's Avatar
mbmike
mbmike is offline
ok everyone I want to add my 2 cents Nitrogen in tires is well worth it. I run a Mercedes Benz service center and yes I sell it for 39.95 and run specials for 9.95. But use it for one reason in my 2 bikes 03 fatboy, 06 street glide living in Phoenix Az. the road temp can exceed 140deg with air the air preasure with heat can exspand that tire 5 to 8 lbs, with Nitrogen temp doesn't effect the PSI, besides NASA, NASCAR, Toru de france boys put it in there tires. They have done it for the last 20 yrs, with a nitrogen generator cheaper made all tires should be filled with it. In a car inproves fuel economy, tires last longer due to air preasure more accurate longer, So all the who think its crap , well buy more tires more often. Hey one more thing does it improve the ride yes, a set of low profile tire with Nitrogen in the tires ride as smooth as full size tires , see the molecules are larger and absorbs more of the road cracks. and if you need to add air any time no problem doesnt hurt anything. Course those guys at Costco do it for free. damm costing me money
Old 04-21-2008, 11:31 PM
FLHXn's Avatar
FLHXn
FLHXn is offline
We have it at work, so I do it for free,, I wouldn't pay a dime for it though,, just fun to hook up the machine and watch it lower/raise and make some cool beeping noises! hehe.. It's supposed to be better! Yeah, ok.
Old 04-22-2008, 03:31 AM
davewear's Avatar
davewear
davewear is offline
if you want to run nitrogen in your tires make sure you get it at a harley dealership or you will void your warranty....
Old 04-22-2008, 05:10 AM
kry226's Avatar
kry226
kry226 is offline
Its kind of funny this thread was posted nearly the same time mine was in the General forum. My 08 SG came from the dealer with metal caps on the valve stems with "N2" inscribed in blue on the tops of the caps.
https://www.hdforums.com/m_3243778/tm.htm
iride1
03-18-2012 05:01 PM
sandpa
05-10-2010 02:25 PM
Raptor1956
01-24-2009 11:26 AM
mopardave
The General Motorcycle Forum
70
12-28-2008 10:49 PM
Rodent
04-30-2006 06:14 PM
Quick Reply: nitrogen in tires
