Fork Tube Relfector
RE: Fork Tube Relfector
I did not have to do it on mine, because I replaced the legs with chrome. I did read on this forum, that taking dental floss or fishing line and run it behind the reflector to cut through the 2 sided tape. Then use goof-off or another glue removing formula. It should be that simple.
Hope this helps, Gene
Do it in this sequence heat it up with a hair dyer till it will wigle a little then spray wd-40 on it then double up on some fishing line and use that like a saw then it should fall of or you will be able to just twist it off then just goof off or goo gone to get the rest of the residue off and then repeat it on the other side. I have taken all the reflectors off my bike and most off of my dads street glide and that was the best way i found to do it.
99octane
General Topics/Tech Tips
08-18-2009 10:26 AM
jonny ebola
07-30-2007 10:50 PM
