08 Roadglide handle bars
I know some of you have changed them out to something different. After some riding time now, What do you like about them? I "think" I need something up and back to me a little bit. I am about 6 foot if that helps any at all. I think that somebody put bars on that were close to Heritage bars? I would like to get away with not having to change anything if at all possible with the cables.
Thanks,
George
Thanks,
George
RE: 08 Roadglide handle bars
George- I changed to the Heritage bars last week. Did about 260 miles today,
much better for me- I'm 5'9". A little higher and ( 1.5") and more pullback (1.5")
than the stock FLTR bars. No cable or wiring changes necessary. You will have
to modify the end of the bar for your TBW on the '08.
I can now sit up straighter and have a little bend at the elbow, instead of leaning
foreward with straight arms.
Check the search function and you will find all kinds of info on your options.
Boxs
Boxs
I have Wild 1's 513 bars on my RG. I like them, but need a little more pullback, would like to try the 515's.
I'm 5'8" and have a bad back, hence the backrest. Best riding position for me is straight up, spine straight.
Good luck.
[IMG]local://upfiles/17072/864F094F3C7C465D9719DF7EE5FCFD8A.jpg[/IMG]
Good luck.
+1 on the Heritage Bars. If you use them order the bars for the police edition, they are designed for the new throttle wire. I am 5' 10" with 34" sleeves. I would like about 2" more back than the Heritage give. See pics.
[IMG]local://upfiles/43876/7E9D6DB3C3584A7AAB120B336FE4C835.jpg[/IMG]
[IMG]local://upfiles/43876/6273905CCEB5478986247A4BDCFF09DB.jpg[/IMG]
Glideman2005,
The wild 1's 513's are 8.5" high and the 515's are 10" high.
Check out their website,
http://www.wild1inc.com/handlebars.html
[IMG]local://upfiles/17072/E198D3A750AB4849A8740F78784D731A.jpg[/IMG]
Do you have the exact part number for these bars? This may be exactly what I need to keep from leaning forward with my arms straight. Thanks
ORIGINAL: mhud
