V & H True Ovals
V & H True Ovals
I am having a problem with my right exhaust loosening up and moving back about an inch farther than the left. It also makes the trike louder.....
Any ideas why and how to fix the problem permanently?
[IMG]local://upfiles/25017/4476DB4C043B4CE0AEACB6E2B837F7DA.jpg[/IMG]
[IMG]local://upfiles/25017/A8FCFD547E674DF8B668EA6E2151E555.jpg[/IMG]
RE: V & H True Ovals
First of all don't use the junk V&H clamps. I wound up re-using my stock clamps.
Tighten as much as you can then get the exhaust hot then retighten. Let them completely cool then retighten. Repeat this procedure one more time and you should be good to go.
Very common issue.
Very common issue.
