Know where to get one of these?
Old 04-17-2008 | 10:28 PM
Gart's Avatar
Gart
Default Know where to get one of these?
Does anybody know where you can get one of these?
It is a type of compression nut that comes in the adjustable back rest kit. It goes into the hexagon hole mid frame to mount the backrest control. I tried to use it per the instructions and it basically stripped itself. (It is also used on the mid-frame air deflectors to mount the deflector to the mid-frame.)
The parts sheet states that you can't buy this separately (no part #, but it is called "Nut, special, self clinching. 0.25-20"). I really don't want to go buy the midframe air deflector just to get the parts if I don't need to.
Thanks if you know where to get one.
Gart
(I tried to post a picture of it but I can't get that to work either.)
Old 04-17-2008 | 10:44 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: Know where to get one of these?
email me the pic an' ah'll post it fer ya....might try yer local nuts/bolts jobber warehouse - them boys can find all kinds of stuff, or steer ya in the right direction!
Old 04-17-2008 | 10:47 PM
CREEPSHOW's Avatar
CREEPSHOW
Sorry redneck, must of asked at the same time Here is the nut in question! Tried to clear up the picture a bit.
Old 04-17-2008 | 10:49 PM
TexasRedneck
blurry, but ah kin make it out - looks like the act of tightening it flares the end out ta make it stay in place?
Old 04-17-2008 | 10:54 PM
Bill03E's Avatar
Bill03E
Looks like an aluminum compression nut with a flair? http://aebike.com/page.cfm?action=de...amp;SKU=BR1777 is this what it looked like or is it something else?
Old 04-17-2008 | 11:05 PM
Gart's Avatar
Gart
The bolt is inserted through the left side of the picture (1/4" bolt). The left edge of the pic is a bit larger than the rest of it to prevent it from being pushed into the frame and loosing it (sort of like a washer). The next area (left 1/3rd of the pic) "was" the six-sided" section that supposedly would keep it from twisting in the six-sided hole in the mid-frame. The section on the right is the "crush or self-clinching" area that compress's and flares out on the inside of the frame.
Once you get it crushed down, you can take the bolt out and the nut stays in there. Even with small hands, there is no way to get anything else in there to work. The bracket for the seat adjuster covers up what limited access there is.
Thanks for looking.
Gart
It is similar to a hollow wall anchor with exception of the hexagon section by the face. It does the same things as:
http://www.acehardwareoutlet.com/(ltcnbv55p00ferqyxlif2k45)/LargeImage.aspx?SKU=51806&Image=51806.jpg
Old 04-17-2008 | 11:06 PM
CREEPSHOW's Avatar
CREEPSHOW
Here is as close as I could find. Lots of nuts there...??
http://manjun88cn.en.alibaba.com/pro...ndoff_nut.html
Old 04-17-2008 | 11:07 PM
TexasRedneck
Try these folks:
http://www.jhpfasteners.com/?gclid=C...FQUgkgodbHcqwQ
Old 04-18-2008 | 02:12 AM
DZLDR's Avatar
DZLDR
Looks like a nut zerk to me,
also called blind nut, huck nut,orcompression nut.
takes a special tool to install them that looks like a pop rivet gun.(small sizes up to 3/8 )
used in places that you have to use a bolt but cannot get to the back side to use a nut.
lemme know if you need a pic of the tool, where to get it or how to use it.
I usemine weekly in my work.
Old 04-18-2008 | 02:26 AM
TruBluUltra's Avatar
TruBluUltra
ORIGINAL: DZLDR
I'm pretty sure that it's actually called a "nutsert"
http://store.nutsandbolts.com/nutser...ts-auveco.html
Quick Reply: Know where to get one of these?
