Zumo Problem/Question
Old 04-14-2008 | 09:25 PM
saweet96's Avatar
saweet96
Default Zumo Problem/Question
Not sure if this is the right area to post my question/problem.
Just installed my Zumo on my new '08 Ultra.
I hard wired it off of the cigarette lighter.
As Iride andoff the Zumo, it turns itself back on. Anyone else have this problem or is it Gremlins?
Spooked in Illinois!
Old 04-14-2008 | 09:30 PM
Gart's Avatar
Gart
Default RE: Zumo Problem/Question
Run that past us one more time for clarification.
Are you saying it shuts off by itself and then comes back on?
Gart
Old 04-14-2008 | 09:34 PM
saweet96's Avatar
saweet96
It is hard wired so it comes on when the bike is running. If I want to turn it off, I hit the off button and it does turn off. Within5 minutes or so it turns itself back on!
Old 04-14-2008 | 10:20 PM
greg09997's Avatar
greg09997
I'm guessing you have a loose wire. When it moves and the connection is restored, the Zumo thinks you've turned the bike on again.
Not a doctor, only play one on TV, but thats my guess.
Old 04-14-2008 | 10:28 PM
Gart's Avatar
Gart
No it should stay off if you power it off. I somewhat agree with Greg. Recheck your connection to make sure both the power and ground are not loose in any way. If you have good connections, contact Garmin.
You may also try: http://www.zumoforums.com/index.php
Good luck.
Gart
Old 04-15-2008 | 04:25 AM
BirchwhiteHD's Avatar
BirchwhiteHD
Is it powering back up on internal battery power?
ZumoForums might ask here as well,some real smart folks with the zumo's
Old 04-15-2008 | 08:23 PM
casique's Avatar
casique
I'm having a similar problem. Mine switches between battery and bike power. My power wire seems ok, so I believe it is a faulty craddle. Someoene else in the Zumo forum was having the same problem. Garmin is sending me a new craddle.
Old 04-15-2008 | 08:25 PM
saweet96's Avatar
saweet96
No its not using the internal battery. But maybe my connection is loose? Didn't know if there was a setting on the Zumo I was missing.
Old 04-15-2008 | 08:30 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Dont know if this will help you out but...you need to make sure that the Zumo is in the cradle all the way.. mine was about to fall out when i caught it before it hit the floor.
__________________
www.Captain-Itch.com
NoMoreSpyders
10-06-2015 09:15 PM
immusicman
Audio Systems
10-20-2014 06:50 PM
Skeet7373
09-25-2012 06:20 AM
magellan
Audio Systems
08-05-2012 02:15 PM
KY HDRider
03-03-2008 07:51 PM
Quick Reply: Zumo Problem/Question
