oil change help
RE: oil change help
ORIGINAL: RD GLD
Mobil 1 20w50 V-Twin in Engine and Primary and Mobil1 75-90 Gear Lube in Tranny. K&N Filter.
Was gonna flame you for askin' and saw you are new. Welcome aboard and ride safe. Get used to using the search feature prior to askin ??'s.
thanks for the advice.
RE: oil change help
You might has well have asked what kind of beer is best!!!
Your going to get a million different answers but here's one that's gauranteed.
Pick your favorite brand. Regular oil is fine, synthetic if you like.
Put engine oil in the engine. An oil that is wet clutch compatible in the primary ( no friction modifiers) and a gear lube in the gear box. A filter you like thatfits your bike.
It's more important that it'schanged within the recommended intervals than the brand of oil you use.
