Ultar Seat Question
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
I'min chesapeake VA, which isn't close, but isn't too far away.
just put a Dual tour on my 02 Ultra which has a 1" lowering kit installed on the rear shocks.Had the same concerns as I am 5' 8" tall with a 29" inseam.
No trouble touching the ground when coming to a stop and can firmly plant feet on the ground if I scoot forward in the seat. (i.e. when backing up).
I previously tried a "close" version of the non tour pak dual tour and found it to be taller than the non "close" tour pak version.
Other observations after 500 miles or so.
[ul][*]It's firm (as you probably are aware) but not uncomfortable. Someone else descibed it as not feeling toogreat at first, but feeling about the same several hours down the road. Very consistent fell to it and you can shift around to accomodate riding style (cruising, twisties etc..)Am looking forward to my first long ride.[*]The seat sits me back an inch or so past stock.I have Khromewerks +2" Street Sweepers and I feel like I am leaning slightly forward to reach them, even with the backrest adjusted all the way forward. May switch to apes or Flanders pull backs next winter. [/ul]
If you are ordering straight from the factory they should be able to custom mold yourseat. When I talked with them, they indicated they could get at least an inch lower that stock.
Finally, I also tried a Saddlemen Explorer (available in leather with backrestfrom Dennis Kirk closeouts for $500) that I would have kept had I not gotten a great deal on this Corbin. The explorer is firm as well and I could plant my feet solidly when stopping. It sits lower than the Corbin. Felt like I was in the bikenot on it. I'vehad an explorer on my softail and they are very well made and comfortable seats. Plus, you can return it if you don't like it.
Good luck.
Deet
Good luck.
Deet
