Kuryakyn curved license plate frame
Just bought the curved license plate frame. Read directions for install. No problem, makes sense. have to remove two 1/2 inch nuts under fender. Question how? I can't hardly get my arm in there to have any room. I don't think my arms are that big. I know someone has installed these before. Help!
Thanks in advance. Jrsess
RE: Kuryakyn curved license plate frame
Quick answer remove the rear tail light. Access nut through hole in fender.
"I neverinstalled onebut recall a post discussing this same problem. Apparently someoneremoved the rear wheel to install the bracket.. Anyway someone chimed in and I believe said you can access the nuts by removing the brake light Assy.. Do not remove the rear wheel."
Hey in turn you can help me out ??? Can you measure the area that the license platefits into the Kuryakyn curved license plate frame ??? I heard the Maryland plate is too large for the Kuryakyn curved license plate frame..
Maryland license plate is 4-1/2" x 8-1/2".
Thanks in advance
Thanks in advance
Yes , the easiest way it to remove the tail light assembly and install it. After installation with the bike at idle check for vibration. It has been found that to much vibration will cause cracking of the flanges that hold it in place. Many have broken and lost the plate while riding. I took a 4 inch piece of 3/4" hose and split it in half. Then slid one half up under the plate holder until it was solid and could not be seen. No more vibration. I have over 10,000 miles with it this way and no cracking.
Ride Safe,
Mike
Ride Safe,
Mike
ORIGINAL: StreetGlide2006
I just installed this on my 08 SG.
What I did was:
1. Jack the bike off the ground
2. Remove the license plate and holder
2. Remove the chrome bracket that goes between the the lower fender light and the saddle bag rails.
This will allow you to get your hand up between the fender and tire to get to the tail light bolts.
A 1/4" drive ratchet and 1/2" short socket worked for me.
Tip: be careful not to let the tail light assembly fall of onto the painted fender after removing the bolts.
What I did was:
mls02
02-17-2014 06:06 PM
Lightyear68
07-28-2013 07:38 PM
