Light Modulator Cruise Control Connection?
My ' 08 Ultra Classic had it's 1,000 mile check up last week. Everything was A-OK. Today I installed a Kisan "Tail Blazer" tail light modulator. It's a simple bulb plug in. No splicing. Within the first 15 minutes of riding after the installation, I noticed the "Check Engine" light on the dash. I returned home and put the original bulb back in. Then, I proceeded onto the interstate and the cruise wouldn't work. When turned on, the typical amber light appeared in the instrument cluster but pressing the "set" button didn't always activate the cruise and turn on the green light. When it did, however, the cruise would release for no reason and I'd have to reset. I took the bike to the dealer and they found a "historic code" which they cleared related to the cruise control. After the repair, on the way home, the problem started up again. My question-Is it possible the bulb modulator may havecaused the cruise to get aweird signal that now has causedit to continue to think the brake is on and hence, release the cruise mode? Is it just sheer coincidence? Having cleared the code, with the original bulb in, any idea why the problem and warning light might come back on?
RE: Light Modulator Cruise Control Connection?
The headlight modulator will not effect the cruise control, but some tail light modifications will. An led bulb will cause problems in some cases with the cruise control dropping out. There was a tech tip issued about this in Nov 2002 regarding the LED use. Did you check the cruise for trouble codes?
Here is how to pull the cruise control dropout codes and what they mean. They tell you why the cruise control disengaged. The module stores the last 8 dropout codes starting with the most recent dropout.
To invoke the readout:
Engine OFF, cruise switch OFF
Push cruise set/resume switch to SET and HOLD it there while switching to IGNITION (do NOT start engine)
RELEASE the set/resume switch and watch the cruise enabled lamp....it will flash out 3 digits encoded as a series of pulses in the following pattern >>> the first digit is string of 1/4 second flashes, then a one second pause; then the second digit is string of 1/4 second flashes, then a one second pause; then the third digit is string of 1/4 second flashes and it stops.....write down the number of flashes in each of the three segments and you will get a three digit code
if you want to verify the flashes you just saw, then push the switch to RESUME and it will repeat the three digit code that you just read.....
to get the next three digit code that is stored, push the switch to SET and three more digits will be pulsed out in the same format as above.....continue advancing the codes by toggling to the SET (or verify them using RESUME)
there are 8 codes stored and once the buffer is empty, the cruise engaged lamp stays on solid.........if you want to repeat all 8 again, then toggle the switch to SET
to exit the readout mode switch the ignition to OFF
You now have 8 three-digit codes written on your arm....their meaning is:
111 No Codes, memory clear
112 Throttle roll off
113 Cruise switch turned off
122 frt or rear brake applied
211 Coast interval longer than 6 seconds (S/C button)
212 speed dropped below 30 mph while s/c button held
213 speed below 26 mph or above 90 mph
221 speed drops more than 15 mph below speed set point
222 speed decrease exceeds 20 mph per second
223 vehicle speed sensor input
231 rpm exceeds 5000
232 tach signal lost
242 high rate of engine rpm change (e.g., hit ice or slipping tire)
341 low voltage
internal failure if code 311, 312, 313, 321, 323, 331, 332, 333, 342, 343, 351, 352, 353, 361, 362, 363, 371, 423, 432, 777
341 low voltage
HDF Tech
08-28-2005 11:40 AM
312, bulb, code, connecting, connection, control, cruise, davidson, harley, headlight, kriss, led, modulator, p0577, streetglide
