I have a Biketronics Smart Load Equalizer on its way and was just wondering where it plugs in? That way if it is inside the fairing I can take it off before it gets here. I have looked for installation instructions but can't find them anywhere. It is going on a 07 RoadGlide.
Yes, it does go under the seat. you just disconnect your light harness and plug it in. If you have a run,turn,brake on the bike the equalizer goes down stream from it.
I have the Kury led front and rear signal light conversions and the Kury led taillight/brakelight and I didn't want to splice there equalizers in so I went with the easy BT plug and play unit.
Yeah the BT units are top quality. And they stand behind their product. Had a Tailbones replaced under their lifetime warranty. No questions asked. Also when I first got my Smart EQ I had an 06. Traded to an 07 and they EQ did not work right. They had a revision and sent me a new one and I mailed the old one back when after it arrived. Same when I traded for an 08. Another revision and no problems with a replacement. Top notch customer service.
